ASUS FX517ZR BIOS
  • quic307
    • Jun 2015
    • 259
    • Greece
    ASUS FX517ZR BIOS
    Hello friends,
    I need bios for the below Asus FX517ZR DA0NJKMBAF0.
    DA0NJKMBAF0
    sn N9NRCX01Y00636B
    model ASUS FX517ZR
    Attached dump faulty.
    Thanks​
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Originally posted by quic307
    Hello friends,
    DA0NJKMBAF0
    sn N9NRCX01Y00636B
    model ASUS FX517ZR
    Thanks​
    Please try dmi added
    • Vava-76
      • Jan 2023
      • Москва
      Прошу чистый-рабочий дамп биоса на эту модель Asus FX517ZR
      I request a clean working BIOS dump for this Asus FX517ZR model
      in English please...
      • peste
        • 14030
        • ROMANIA
        post S/N, full name and model, motherboard model,etc.
        post the contents of the bios chip even if it is corrupted..
        read the forum rules..
        https://www.badcaps.net/forum/troubl...ore-posting​
        • mkdj
          by mkdj
          Dear all,
          10-19-2025, 04:41 AM
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • pirati
          by pirati
          10-27-2025, 04:20 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
