ASUS FX517ZR BIOS
  • quic307
    • Jun 2015
    • 255
    • Greece
    ASUS FX517ZR BIOS
    Hello friends,
    I need bios for the below Asus FX517ZR DA0NJKMBAF0.
    DA0NJKMBAF0
    sn N9NRCX01Y00636B
    model ASUS FX517ZR
    Attached dump faulty.
    Thanks​
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Originally posted by quic307
    Hello friends,
    DA0NJKMBAF0
    sn N9NRCX01Y00636B
    model ASUS FX517ZR
    Thanks​
    Please try dmi added
    • Vava-76
      • Jan 2023
      • Москва
      Прошу чистый-рабочий дамп биоса на эту модель Asus FX517ZR
      I request a clean working BIOS dump for this Asus FX517ZR model
      in English please...
      • peste
        • Dec 2016
        • 13174
        • ROMANIA
        post S/N, full name and model, motherboard model,etc.
        post the contents of the bios chip even if it is corrupted..
        read the forum rules..
        https://www.badcaps.net/forum/troubl...ore-posting​
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • kodox
          Asus ExpertBook B1400CB Bios Dump Needed
          by kodox
          need original bios dump, original bios has flashed by other technician before me.
          attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
          unit info:
          Model: Asus ExpertBook B1400CBA-0711A1235U
          S/N: R6NXNZ006657238
          CN: 7F6F
          Mainboard Code: B1500CBA R2.1...
          08-16-2025, 12:20 PM
