GWTN156-5BK BIOS corrupt?
This topic has been answered.
  • Norag33
    • Mar 2024
    • 24
    • Cuba
    Hello everyone, I have a Gateway GWTN156-5BK that a friend just gave me, it turned on normally but a message always appeared complaining about corrupted fTPM nv, I always select the option to keep that data and continue, but today out of curiosity I simply selected the option to clear fTPM data and next to that my laptop turned off and I couldn't turn it back on, I cleaned a CMOS by removing the battery but it didn't work, the laptop doesn't even turn on the fan. I suspect that the BIOS was corrupted in some way, if anyone knows how to solve that problem or can help me with a BIOS dump for this laptop model I would greatly appreciate it.
  • Answer selected by Norag33 at 06-14-2025, 11:04 PM.
    Norag33
    • Mar 2024
    • 24
    • Cuba
    Originally posted by SMDFlea
    Post your corrupt backup and the laptop serial number https://www.badcaps.net/forum/troubl...before-posting
    Hope this helps someone else
      • 22283
      • Norag33
        • Mar 2024
        • 24
        • Cuba
        SMDFlea sorry for the late reply, I was downloading the software of my programmer and my internet is so slow, I can only give you the serial number because my programmer was unable to read the BIOS chip it says the drive does not respond, seems like it is damaged and I'm sure that I didn't damaged it because I was very gentle when I was unmounting it from the board, and I don't think that it is a problem of my programmer because it can read other chips normally, it is a RT809H
        S/N 1GWTN1565BK1A20L010968
        • Norag33
          • Mar 2024
          • 24
          • Cuba
          Hello everyone, today I was able to make the laptop work with the GWTN156-4GR BIOS, it is a similar model of laptop, I had to take the BIOS chip of a Lenovo Yoga 2 since the laptop chip got damaged, I programed it with the new BIOS an solder it into motherboard, the laptop was able to turn on but if I unplug the carger it becomes unable to turn on again, would it be a problem of compatibility of the BIOS or chip compatibility problem?
          The BIOS chip I'm using is 25B64BSIG
          • Norag33
            • Mar 2024
            • 24
            • Cuba
            Update, actually tried with two different BIOS, the GWTN156-4GR and GWTN156-11BK, both had same behavior, laptop turn on only the first time after BIOS install, then it only turn on randomly, it is almost unable to boot windows and the few times i could reach the Windows desktop it goes black screen suddenly but laptop keeps powered, otherwise it always reboot when triying to boot Windows ang got stuck in Gateway logo.
            • Norag33
              • Mar 2024
              • 24
              • Cuba
              Last update, this will sound stupid, but I was flashing the wrong chip all this time, I removed the spi memory from the EC, I actually found the real BIOS chip and flashed it with the GWTN156-4GR BIOS, it's actually the same thing. instead of 16 GB of RAM, it will be reduced to 8 GB, I was actually lucky because if I had flashed the BIOS of the GWTN156-11BK my laptop would probably be fried since mine is AMD and the 11BK is Intel. In any case, I think that my BIOS is not corrupt, I am suspecting that the problem is the ITE8987E since the problems that the laptop is presenting are related to the function that it performs, therefore I will upload the dump of my original BIOS since it probably does not is corrupt and I will close this post
              • Norag33
                • Mar 2024
                • 24
                • Cuba
                • Norag33
                  • Mar 2024
                  • 24
                  • Cuba
                  SMDFlea
                  This backup is not corrupt it is actually working, I just found what was the problem with my laptop, and it was not BIOS
                  • wamo
                    • Apr 2018
                    • 28
                    • MX
                    SMDFlea
                    HI!
                    Could you share what was the fault that you finally found in your equipment?
                    I have the other model, the 11BK, that does exactly the same thing you mention, I almost think it is the ITE but I don't know exactly how to corroborate that error.
                    Thanks for the contribution
                    • FalconPunch
                      Surface Pro X 1876 Bios corrupted
                      by FalconPunch
                      Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
                      Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
                      08-09-2025, 03:56 AM
                    • zlr8r
                      Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
                      by zlr8r
                      Greetings
                      I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
                      Serial Number: 5CG3202C16
                      Product #/SKU: 739P0AV
                      CT Number: PRTUE00WBI30YX
                      Description: HP ZBook Firefly 14 inch G10
                      BuildID: 23WWWGAZ602#SABU#DABU
                      Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
                      MAC address not found.
                      • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
                      10-28-2025, 01:56 PM
                    • TripTop
                      Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                      by TripTop
                      Hi
                      i have dell latitude E7270 with following symptoms:
                      - takes long time to restart.
                      - sometimes powers on and then off
                      - sometimes while working it just dies,
                      From googling online bios clean could possible resolve this?
                      i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                      As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                      I reinstall...
                      09-09-2024, 02:05 PM
                    • macabook
                      by macabook
                      🧩 Initial Issue
                      07-24-2025, 02:17 PM
                    • grimacelord
                      by grimacelord
                      Hello there.
                      History:
                      03-15-2023, 03:29 PM
