Asus S533E bios Password
  • Pascoalcaz
    • Jan 2023
    • 14
    • Angola
    Bios Dear all, Please I need to remove bios password from this dump. I tried the but no power on. Please help thanksClick image for larger version
  • Pascoalcaz
    • Jan 2023
    • 14
    • Angola
    dump
    • hoaca388
      Badcaps
      • Jan 2022
      • 11659
      Originally posted by Pascoalcaz
      dump
      Serial number ?
      • LEO037_2029_
        BIOS_LEGEND
        • Nov 2023
        • 83
        • Argentina
        Pascoalcaz try this bios UNLOCKED . and tell me if work for you...
      • Pascoalcaz
        • Jan 2023
        • 14
        • Angola
        turns on but no LCD signal
        • Pascoalcaz
          • Jan 2023
          • 14
          • Angola
          Originally posted by hoaca388
          Serial number ?
          here it is
          • hoaca388
            Badcaps
            • Jan 2022
            • 11659
            here it is
            My eyesight is bad, can you write it down ?
            • Pascoalcaz
              • Jan 2023
              • 14
              • Angola
              S.N M4N0CV17H55817D
              X521E0
              69N1BM13C51​
            • hoaca388
              Badcaps
              • Jan 2022
              • 11659
              S.N M4N0CV17H55817D
              X521E0
              69N1BM13C51​
              X521EQ
              • Pascoalcaz
                • Jan 2023
                • 14
                • Angola
                X521EQ
                IT DOESN'T TURN ON WHEN I CLICK ON THE POWER THE LED FLASHES AND WHEN I TRY TO CLICK ON THE POWER AGAIN THE LED NO LONGER FLASHES
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11659
                  Reflash the original file and see if it works.
                  • Pascoalcaz
                    • Jan 2023
                    • 14
                    • Angola
                    Thank you for your patience
                    • Pascoalcaz
                      • Jan 2023
                      • 14
                      • Angola
                      I TESTED THE POSTED DUMP AND REALIZED IT WAS CORRUPT AS I HAVE MADE TWO BACKUPS I TESTED THIS ATTACHED DUMP IT WORKS PLEASE HELP ME WITH UNLOCKING THIS DUMP
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11659
                        You have not answered my question.
Name:	2024-08-15 20_23_54-Asus S533E bios Password - Badcaps.png
                        • Pascoalcaz
                          • Jan 2023
                          • 14
                          • Angola
                          THE ORIGINAL FILE WORKS I TRIED TO MODIFY IT AND IT STILL DOESN'T WORK
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11659
                            If you don't have any hardware errors then the file in #9 should work.
                            • Pascoalcaz
                              • Jan 2023
                              • 14
                              • Angola
                              original that first one I posted doesn't work but this dump does please help me with this
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11659
                                Ok. I hope you are right.
                                • Pascoalcaz
                                  • Jan 2023
                                  • 14
                                  • Angola
                                  IT WORKED BUT IT DOES NOT RECOGNIZE THE MOUSE AND THE SSD
                                    SMDFlea commented
                                    Editing a comment
                                    Is there something wrong with your caps lock key, please post in lower case ,not UPPER CASE
                                • Pascoalcaz
                                  • Jan 2023
                                  • 14
                                  • Angola
                                  Thank you very much everyone Here is the corrected and working bios
                                  • Buzzfuzz2k
                                    Bios password removal on a Unowhy dump
                                    by Buzzfuzz2k
                                    Hi Everyone,
                                    I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                    The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                    the Computer is a Unowhy small pc
                                    N° UYM6524702229
                                    After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                    My first attempt was to get the bios dump from windows...
                                    11-13-2023, 07:37 AM
                                  • Przmx
                                    Asus Vivobook S14 Flip OLED TP3402 AFUWINGUI memory dump error for decoding lost BIOS password
                                    by Przmx
                                    I'm an owner of an Asus Vivobook S 14 Flip OLED TP3402 laptop (TP3402ZA-KN063WA)
                                    with serial number: NBN0LP019584459
                                    and I lost the BIOS password that I set in this laptop one year ago.
                                    I tried to recover the password using the AMITSESetup method described on the forum. I found that it is possible by software to obtain the BIOS file from my computer (afuwin.rom), but when trying to do so in AFUWINGUIx64 I received the error number 31 "Unable to read contents from specified file" shown in the attachment. I don't have a programmer,...
                                    06-01-2024, 12:12 PM
                                  • snpetit
                                    Asus FA706IH Bios Password remove
                                    by snpetit
                                    i need some help :-/
                                    i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
                                    Could you please remove all password related stuff from this bios. A hate Asus....
                                    Thanks in advance!...
                                    01-10-2025, 09:17 AM
                                  • DynaxSC
                                    by DynaxSC
                                    06-14-2024, 03:49 PM
                                  • OnRepair1
                                    Looking For a bios dump for an Asus S533E
                                    by OnRepair1
                                    Hey im looking for some help, this laptop starts but the fan dosen't spin even when hot, the fan works fine.
                                    Bios dump for Asus S533E
                                    SF114-34-C0B1
                                    Motherboard: X521EA REV: 2.0
                                    SN: M3N0CV22Z36213D
                                    Here's my BK bios
                                    Thanks...​...
                                    05-01-2024, 10:38 AM
