Asus S533E bios Password
  • Pascoalcaz
    • Jan 2023
    • 14
    • Angola
    Bios Dear all, Please I need to remove bios password from this dump. I tried the but no power on. Please help thanksClick image for larger version
  • Pascoalcaz
    • Jan 2023
    • 14
    • Angola
    dump
    • hoaca388
      Badcaps
      • Jan 2022
      • 12122
      Originally posted by Pascoalcaz
      dump
      Serial number ?
      • LEO037_2029_
        BIOS_LEGEND
        • Nov 2023
        • 83
        • Argentina
        Pascoalcaz try this bios UNLOCKED . and tell me if work for you...
      • Pascoalcaz
        • Jan 2023
        • 14
        • Angola
        turns on but no LCD signal
        • Pascoalcaz
          • Jan 2023
          • 14
          • Angola
          Originally posted by hoaca388
          Serial number ?
          here it is
          • hoaca388
            Badcaps
            • Jan 2022
            • 12122
            here it is
            My eyesight is bad, can you write it down ?
            • Pascoalcaz
              • Jan 2023
              • 14
              • Angola
              S.N M4N0CV17H55817D
              X521E0
              69N1BM13C51​
            • hoaca388
              Badcaps
              • Jan 2022
              • 12122
              S.N M4N0CV17H55817D
              X521E0
              69N1BM13C51​
              X521EQ
              • Pascoalcaz
                • Jan 2023
                • 14
                • Angola
                X521EQ
                IT DOESN'T TURN ON WHEN I CLICK ON THE POWER THE LED FLASHES AND WHEN I TRY TO CLICK ON THE POWER AGAIN THE LED NO LONGER FLASHES
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12122
                  Reflash the original file and see if it works.
                  • Pascoalcaz
                    • Jan 2023
                    • 14
                    • Angola
                    Thank you for your patience
                    • Pascoalcaz
                      • Jan 2023
                      • 14
                      • Angola
                      I TESTED THE POSTED DUMP AND REALIZED IT WAS CORRUPT AS I HAVE MADE TWO BACKUPS I TESTED THIS ATTACHED DUMP IT WORKS PLEASE HELP ME WITH UNLOCKING THIS DUMP
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12122
                        You have not answered my question.
Name:	2024-08-15 20_23_54-Asus S533E bios Password - Badcaps.png
                        • Pascoalcaz
                          • Jan 2023
                          • 14
                          • Angola
                          THE ORIGINAL FILE WORKS I TRIED TO MODIFY IT AND IT STILL DOESN'T WORK
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12122
                            If you don't have any hardware errors then the file in #9 should work.
                            • Pascoalcaz
                              • Jan 2023
                              • 14
                              • Angola
                              original that first one I posted doesn't work but this dump does please help me with this
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12122
                                Ok. I hope you are right.
                                • Pascoalcaz
                                  • Jan 2023
                                  • 14
                                  • Angola
                                  IT WORKED BUT IT DOES NOT RECOGNIZE THE MOUSE AND THE SSD
                                    SMDFlea commented
                                    Editing a comment
                                    Is there something wrong with your caps lock key, please post in lower case ,not UPPER CASE
                                • Pascoalcaz
                                  • Jan 2023
                                  • 14
                                  • Angola
                                  Thank you very much everyone Here is the corrected and working bios
                                  • Buzzfuzz2k
                                    Bios password removal on a Unowhy dump
                                    by Buzzfuzz2k
                                    Hi Everyone,
                                    I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                    The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                    the Computer is a Unowhy small pc
                                    N° UYM6524702229
                                    After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                    My first attempt was to get the bios dump from windows...
                                    11-13-2023, 07:37 AM
                                  • Przmx
                                    Asus Vivobook S14 Flip OLED TP3402 AFUWINGUI memory dump error for decoding lost BIOS password
                                    by Przmx
                                    I'm an owner of an Asus Vivobook S 14 Flip OLED TP3402 laptop (TP3402ZA-KN063WA)
                                    with serial number: NBN0LP019584459
                                    and I lost the BIOS password that I set in this laptop one year ago.
                                    I tried to recover the password using the AMITSESetup method described on the forum. I found that it is possible by software to obtain the BIOS file from my computer (afuwin.rom), but when trying to do so in AFUWINGUIx64 I received the error number 31 "Unable to read contents from specified file" shown in the attachment. I don't have a programmer,...
                                    06-01-2024, 12:12 PM
                                  • snpetit
                                    Asus FA706IH Bios Password remove
                                    by snpetit
                                    i need some help :-/
                                    i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
                                    Could you please remove all password related stuff from this bios. A hate Asus....
                                    Thanks in advance!...
                                    01-10-2025, 09:17 AM
                                  • DynaxSC
                                    by DynaxSC
                                    06-14-2024, 03:49 PM
                                  • Ahari
                                    by Ahari
                                    I...
                                    08-13-2025, 06:12 AM
