Asus S533E bios Password
  • Pascoalcaz
    • Jan 2023
    • 14
    • Angola
    Bios Dear all, Please I need to remove bios password from this dump. I tried the but no power on. Please help thanksClick image for larger version
  • Pascoalcaz
    • Jan 2023
    • 14
    • Angola
    dump
    • hoaca388
      Badcaps
      • Jan 2022
      • 12682
      Originally posted by Pascoalcaz
      dump
      Serial number ?
      If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
      Subscribe to support us. It only takes 1 minute:
      https://www.badcaps.net/settings/subscriptions
      • LEO037_2029_
        BIOS_LEGEND
        • Nov 2023
        • 85
        • Argentina
        Pascoalcaz try this bios UNLOCKED . and tell me if work for you...
      • Pascoalcaz
        • Jan 2023
        • 14
        • Angola
        turns on but no LCD signal
        • Pascoalcaz
          • Jan 2023
          • 14
          • Angola
          Originally posted by hoaca388
          Serial number ?
          here it is
          • hoaca388
            Badcaps
            • Jan 2022
            • 12682
            here it is
            My eyesight is bad, can you write it down ?
            • Pascoalcaz
              • Jan 2023
              • 14
              • Angola
              S.N M4N0CV17H55817D
              X521E0
              69N1BM13C51​
            • hoaca388
              Badcaps
              • Jan 2022
              • 12682
              S.N M4N0CV17H55817D
              X521E0
              69N1BM13C51​
              X521EQ
              • Pascoalcaz
                • Jan 2023
                • 14
                • Angola
                X521EQ
                IT DOESN'T TURN ON WHEN I CLICK ON THE POWER THE LED FLASHES AND WHEN I TRY TO CLICK ON THE POWER AGAIN THE LED NO LONGER FLASHES
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12682
                  Reflash the original file and see if it works.
                  • Pascoalcaz
                    • Jan 2023
                    • 14
                    • Angola
                    Thank you for your patience
                    • Pascoalcaz
                      • Jan 2023
                      • 14
                      • Angola
                      I TESTED THE POSTED DUMP AND REALIZED IT WAS CORRUPT AS I HAVE MADE TWO BACKUPS I TESTED THIS ATTACHED DUMP IT WORKS PLEASE HELP ME WITH UNLOCKING THIS DUMP
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12682
                        You have not answered my question.
Name:	2024-08-15 20_23_54-Asus S533E bios Password - Badcaps.png
                        • Pascoalcaz
                          • Jan 2023
                          • 14
                          • Angola
                          THE ORIGINAL FILE WORKS I TRIED TO MODIFY IT AND IT STILL DOESN'T WORK
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12682
                            If you don't have any hardware errors then the file in #9 should work.
                            • Pascoalcaz
                              • Jan 2023
                              • 14
                              • Angola
                              original that first one I posted doesn't work but this dump does please help me with this
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12682
                                Ok. I hope you are right.
                                • Pascoalcaz
                                  • Jan 2023
                                  • 14
                                  • Angola
                                  IT WORKED BUT IT DOES NOT RECOGNIZE THE MOUSE AND THE SSD
                                    SMDFlea commented
                                    Editing a comment
                                    Is there something wrong with your caps lock key, please post in lower case ,not UPPER CASE
                                • Pascoalcaz
                                  • Jan 2023
                                  • 14
                                  • Angola
                                  Thank you very much everyone Here is the corrected and working bios
                                  • ronaldopdias
                                    ASUS ROG Strix B660-I Gaming WiFi – BIOS dump vs ASUS CAP size mismatch, need corruption check, please.
                                    by ronaldopdias
                                    I’m troubleshooting an ASUS ROG Strix B660-I Gaming WiFi motherboard and I’m a bit stuck at the BIOS level. What I’ve tried so far
                                    • Attempted to flash the BIOS using the USB BIOS FlashBack (Q-Flash) port with a properly formatted FAT32 USB drive.
                                    • BIOS file downloaded directly from the official ASUS support page.
                                    • Followed the exact FlashBack procedure (correct port, renamed file, standby power only).
                                    Issue:
                                    The FlashBack LED does not blink at all — no activity whatsoever. Further investigation
                                    Because FlashBack didn’t work, I:
                                    • Removed the BIOS SPI IC from
                                    02-04-2026, 03:16 AM
                                  • ArkzG
                                    [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                                    by ArkzG
                                    Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                                    What I currently have available:
                                    - Model: FA506NF (2021)
                                    - BIOS chip: GD25LQ16 (16Mbit/2MB)
                                    - Tools: CH341A programmer ready to use
                                    Does anyone have either a clean 2MB .bin dump of this model,...
                                    09-26-2025, 09:34 PM
                                  • pirati
                                    by pirati
                                    10-27-2025, 04:20 PM
                                  • gandamonteiro
                                    ASUS A407UB (36AM1SB1) Rev 2.0 – Full 8MB BIOS Dump Request
                                    by gandamonteiro
                                    Hello.
                                    I am looking for a FULL 8MB BIOS dump for:
                                    ASUS A407UB
                                    Board: 36AM1SB1
                                    Rev: 2.0
                                    The laptop has no 3.3V rails after a bad BIOS flash.
                                    Originally the board powered on abnormally (CPU heating as soon as adapter was plugged).
                                    After flashing an incomplete BIOS image, the board is now dead (no 3.3V, no boot).
                                    What was tried:
                                    - Read BIOS guides and recovery methods
                                    - Used official ASUS BIOS file (partial image)
                                    - Tried flashing with external SPI programmer
                                    - Recovery was not successful
                                    Request:...
                                    12-21-2025, 09:01 AM
                                  • banshee_banshee
                                    ASUS ROG Crosshair vii hero bios dump
                                    by banshee_banshee
                                    Hello everyone.
                                    Can anyone provide a BIOS dump for this board? The SPI flash chip failed. After replacing the chip, I tried flashing the BIOS from the Asus website using Flashback.
                                    The BIOS loads successfully, but the board doesn't boot. It freezes on the logo and prompts me "to press Del or F2" to enter the BIOS.
                                    The postcode is 0d, and the keyboard doesn't respond. I've tried different BIOS versions, reset the CMOS, and the only thing left is flashing a dump from a donor.
                                    I'd appreciate any ideas, any help, and, of course, if anyone has a working dump....
                                    02-09-2026, 01:59 AM
