HP Clean VSS2 dumps,fix Endpoint Security error
  • bert-bert
    • Oct 2024
    • 25
    • Austria
    Originally posted by SMDFlea
    All feedback is welcome, negative or otherwise. To say that it has killed the laptop though is,quite frankly .I did have a look at your bios --> https://www.badcaps.net/forum/troubl...85#post3575185 ,and your Gbe region is corrupt, it is filled with FF`s. Compare it to one of the others in the thread and you`ll see there is some code in the others.
    Well, to say it killed the laptop is definitivly not the right wording. Sorry. I should have said it just did not work.
    I tried the patch on some random 840 G6 BIOS I found here that had produced EC errors and later on on the BIOS from danito to unlock MPM again. Both were unsuccessful. The laptop didn't come alive.
    Now the BIOS from hoaca388 works perfectly, but also only on the second try. On the first try I had also yellow-orange blinking pattern on the charge LED. Afterwards I read out the non-working BIOS and somehow the chip got modified a lot. Maybe the BIOS tries to write back to itself and failed because I didn't solder well.
    I guess I still have to learn proper hot-air-soldering.
    So, probably this error report ist just me not being able to solder, but I'll not try the non-working files any more, as I still soldered around much too much in this mainboard.
    And the FF's are there because I at first tried to read out the BIOS with an adapter without unsodering, but somehow the mainboard came alive a little without power supply, just with the CH341, and destroyed the chip - it even set the write protection flags, so I had to buy a new BIOS chip.
    But now everything works - yeah!
    • RODAKSAN
      • Jun 2022
      • 17
      • Mexico
      Models,Offsets and filesize:
      440 G8, 450 G8, 830 G8 ,840 G8, X360 1040 G8. 188A048-18C7FFF-3DFB8
      Script filename:
      188A048-18C7FFF-3DFB8.mps
      Hi, I've tried with my Elitebook 830 G8, after main BIOS reprogram (due a forgotten BIOS passwd), it show me the "HP Endpoint Security Controller Problem" message. I follow te readme instructions and reprogrammed the main BIOS with endpoint.bin.
      I still having the same endpoint error, can you help me?
        • 22415
        Post your backups in the 830 G8 thread and someone might be able to help. https://www.badcaps.net/forum/troubl...-unlock-830-g8 .Give an explanation of what you did to remove the password etc
        • kalukramer
          • Nov 2023
          • 23
          • Portugal
          I have a 850 G6 but have this error, I tryed the "flea" scripts but wont work.
          can you help?
            • 22415
            can you help?
            Please read the PM i sent you, you have a request already in one thread - https://www.badcaps.net/forum/troubl...em#post3592413
            Read the rules - https://www.badcaps.net/forum/troubl...before-posting
            • kalukramer
              • Nov 2023
              • 23
              • Portugal
              #26
              Sorry., and thanks
              • graziano61
                • Jul 2016
                • 20
                • Italy
                #27
                Hi,need endpoint security fix file for HP ProOne G5 23.5
                HP 440 ProOne G5 23.5 I79700T 16Gb ram sn 8CG94687QK
                p/n 7PG48EA#ABZ
                Bios file uploaded​
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12513
                  #28
                  p/n 7PG48EA#ABZ
                  Bios file uploaded​
                  # 1
                  ​https://www.badcaps.net/donate
                  • Echoo
                    • Apr 2018
                    • 93
                    • Budapest
                    #29
                    Hi!
                    Unfortunately, the script execution ends as shown in the image!
                    TĂ­pus: X360 1030 G4
                    SN: 5CD0189GDS
                    PN: 7Yl45EA#ABH
                      • 22415
                      Originally posted by Echoo
                      Hi!
                      It should only be used with the main bios, not the EC_Bios
                      • Echoo
                        • Apr 2018
                        • 93
                        • Budapest
                        #31
                        I see, so with the 256 chip?
                          SMDFlea commented
                          Editing a comment
                          If that is the main bios yes. Some boards have a 32MB and 16MB bios, the 16MB being the EC_Bios and the 32MB the main. Some boards have two 32MB chips, by looking at the code with a hex editor you can tell which is which, sometimes you can find a schematic and you can find which is which from that, and sometimes there will be a silkscreen on the board saying MAIN , EC_BIOS.
                      • ahmed100
                        • Mar 2023
                        • 47
                        • Maroc
                        #32
                        Script filename:
                        worked for 830 G8. thank you
                          • 22415
                          Models,Offsets and file size:
                          455 G7, mt44 Thin Client. 21048-46FFF-25FB8
                          Script filename:
                          21048-46FFF-25FB8.mps
                            • 22415
                            450 G9. 1991048-19CEFFF-3DFB8
                            Script filename:
                            1991048-19CEFFF-3DFB8.mps​
                            • Udemzy
                              • May 2017
                              • 168
                              • Guatemala
                              #35
                              455 G7. 21048-46FFF-25FB8
                              Script filename:
                              21048-46FFF-25FB8.mps​
                              Can this also work for 1030 G7
                              • Udemzy
                                • May 2017
                                • 168
                                • Guatemala
                                #36
                                830 G7, 840 G7 18EA048-190FFFF-25FB8
                                Script filename:
                                18EA048-190FFFF-25FB8.mps
                                Let me try this with the 1030 g7
                                  SMDFlea commented
                                  Editing a comment
                                  I checked, it`s ok.
                                • 22415
                                440 G7, 450 G7. A8C048-AB1FFF-25FB8
                                Script filename:
                                A8C048-AB1FFF-25FB8.mps
                                • amiralipay
                                  • Oct 2022
                                  • 17
                                  • iran
                                  #38
                                  Script filename:
                                  A8C048-AB1FFF-25FB8.mps​
                                  hii work but m2 no detect
                                  • elmasryomda
                                    • Aug 2016
                                    • 15
                                    • egypt
                                    #39
                                    how get info(sn- bild id- sku number -...)
                                    • nistel
                                      • Aug 2014
                                      • 33
                                      • Bulgaria
                                      #40
                                      Do anyone know the offsets for HP EliteOne 800 G4 Touch
