Asus Vivobook X712J bios
  • brock-s
    • Dec 2010
    • 42
    I am attempting to remove a power-on password on an Asus Vivobook X712J, sn MG7N0CV08765227C.
    The motherboard is X512A R.20 (on the silkscreen), and 13NB0KS0AM0101, 13N1-78A0101 (on sticker).
    The EEPROM chip is 25B127DSIG by GigaDevice.
    Attached is the BIOS dump as received. I have tried the info posted at BIOS guides, methods, resources and tools but when XORing the key found with the decryption key (posted by SMDFlea here:
    https://www.badcaps.net/forum/troubl...=2#post1544866 ), it gives an error indicating the result is non-printable ascii. (Attached is a screenshot of the key section found).
    Not sure if I'm doing something wrong or if that key doesn't apply to this model. Can someone check if I'm doing something wrong, or if there's another approach that should be used.
    (note: I have a second one of these laptops with the same problem)
  • hoaca388
    Badcaps
    • Jan 2022
    • 11718
    https://www.badcaps.net/forum/troubl...=2#post1544866​ ), it gives an error indicating the result is non-printable ascii. (Attached is a screenshot of the key section found).
    Post original backup bios and serial number .
    • brock-s
      • Dec 2010
      • 42
      Thank you for the reply. I will be able to in about 8 hours. (the serial number is MG7N0CV08765227C, the zipped bin file was originally attached but has dis-appeared from the posting)
      • brock-s
        • Dec 2010
        • 42
        Original BIOS re-uploaded. Asus Vivobook X712J serial number MG7N0CV08765227C.
        • hoaca388
          Badcaps
          • Jan 2022
          • 11718
          X712JA
          • brock-s
            • Dec 2010
            • 42
            THANK YOU! That worked, power-on password gone! As I mentioned in the first post, I have two of these laptops. The second is the same model, with the serial number: M7N0CV08765227C. I don't mind doing the work if you can give me some guidance on the process to use. If you'd rather do it and post back the bios that is fine as well. Attached is the BIOS dump from the 2nd laptop.
            • hoaca388
              Badcaps
              • Jan 2022
              • 11718
              File's corrupted.
              • brock-s
                • Dec 2010
                • 42
                Will get another dump tomorrow (and this time check the compressed size before i upload)
                • brock-s
                  • Dec 2010
                  • 42
                  Re-upload of new dump.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11718
                    XXX
                    • brock-s
                      • Dec 2010
                      • 42
                      Thank you! That one also worked without any problems. I am sincerely grateful for your time and help!
                      (To anyone who happens upon this in the future, this is an example of the importance of donating to keep this site alive. This thread is an example of two laptops saved, and there have been many others where I simply found the info I needed without having to post. Without this site, many machines would not have been fixed or not have been fixed so easily.)
                      • razor_amd
                        by razor_amd
                        12-15-2020, 07:07 PM
                        ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                        This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                        09-07-2024, 02:50 AM
                      • lrouw84
                        Asus vivobook s510ua bios changed to x510un
                        by lrouw84
                        Hi there,
                        I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                        I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                        01-28-2023, 01:31 PM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • TOMÁŠ
                        Asus vivobook k513e bios request
                        by TOMÁŠ
                        Device:laptop
                        Brand: asus
                        Model: vivobook k513e
                        Motherboard: x513ea
                        SN: M5N0CV20H570216
                        Hi, I have problem with asus vivobook k513e. Came to with no pictures I found dump and flashed in to it, was working but did not see in bios ssd, so found another bios file now I can see ssd but laptop lagging evenin bios, also i opened hex editor and change serial number, maybe i did something?
                        sometimes not usable so i think its need beter bios, maybe fixing original or brand new but i don't know how to make it. Please can someone help me with this. Thanks for your help...
                        11-14-2024, 05:49 PM
