HP Omen 17- ck0490nd bios request
  • dr.thodt
    • Apr 2016
    • 84
    • Netherlands
    I've a HP Omen 17- ck0490nd which has the proper voltages on the coils.
    The bios communicates with the cpu on pin 2 and 5 only for a second and then all communication is lost.
    One of the fans keeps turning, the other doesn't.
    The info on the bottom cover:
    SN# 5CD150GBHX
    ProdID: 4B735EA#ABH
    OMEN by HP Laptop 17-ck040nd
    Stickers on the inside of the bottom cover:
    HT-01 E316987
    _E419 21 10 08 B4
    PA 2021.11.09.E
    MTP4DG3LBATP00
    146600YND11103A
    TFQ38G3LTP1014840023
    Many thanks in advance.
  • peste
    • 13448
    • ROMANIA
    SN# 5CD150GBHX
    ProdID: 4B735EA#ABH
    HT-01 E316987
    _E419 21 10 08 B4
    PA 2021.11.09.E
    MTP4DG3LBATP00
    146600YND11103A
    try post #13..
    https://www.badcaps.net/forum/troubl...eo#post3304859
    • dr.thodt
      • Apr 2016
      • 84
      • Netherlands
      Originally posted by peste
      Thanks Peste,
      This bios gets the laptop to post and boot. Can you tell me the start and end address of the DMI region so I can inject this data?
      That would be the cherry on top.
      • peste
        • 13448
        • ROMANIA
        Thanks Peste,
        DMI 701000 - 702FFF
        KEYWIN 786000 - 78603F​
        • dr.thodt
          • Apr 2016
          • 84
          • Netherlands
          DMI 701000 - 702FFF
          Thanks.
          I get a Bios CRC error 502 and it's in Manufacture Programming Mode Is In Unlock Mode. While I am probably able to fix the latter, I found out the bios is password locked. Is this password in the original's DMI area or is it in the bios you revered to? I wonder if I am able to get the CRC error out of the way.
          Some help is appreciated.
          • peste
            • 13448
            • ROMANIA
            Thanks.
            the bios from station #13 is virgin, it has no password.. copy the DMI interval from the laptop bios to the virgin bios.. use the HxD program, put both bios into it and (copy-paste) the interval..
            • dr.thodt
              • Apr 2016
              • 84
              • Netherlands
              I injected my DMI area and key win in the areas you pointed me at. I did notice that the virgin bios was in Manufacture Programming mode unlocked. I'm not 100% sure I saw the crc error 502 with the virgin. I'd have to check that. But this admin password in the bios is bothering me a bit. I'll contact the customer on that. Or I could blank it if I knew its offset.
              • JoWed
                Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                by JoWed
                Hello Community,
                I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                07-01-2025, 09:32 AM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • zenius
                by zenius
                12-08-2024, 06:13 AM
              • farizmohammed
                HP Omen 15 Bios Request LA-H482P Rev 2.0
                by farizmohammed
                I’m trying to recover a bricked HP Omen 15 laptop and need help repairing or finding a clean BIOS dump.
                šŸ–„ļø Laptop Model: HP Omen 15-dh series
                šŸ”¢ Serial Number: CND94945KY
                šŸ”§ Motherboard: FPC54 LA-H482P Rev: 2.0
                What happened:
                I was updating the BIOS, but unfortunately the laptop turned off during the process. Now, there's no display, fans spin, and the Caps Lock LED blinks in a pattern: 4 long + 2 short, which indicates BIOS corruption.
                I attached the dump I'd really appreciate if anyone could help:
                Thanks in advance for any help!...
                07-29-2025, 02:08 AM
              • Wahaz
                by Wahaz
                10-30-2023, 08:42 PM
