HP Omen 17- ck0490nd bios request
  • dr.thodt
    • Apr 2016
    • 87
    • Netherlands
    I've a HP Omen 17- ck0490nd which has the proper voltages on the coils.
    The bios communicates with the cpu on pin 2 and 5 only for a second and then all communication is lost.
    One of the fans keeps turning, the other doesn't.
    The info on the bottom cover:
    SN# 5CD150GBHX
    ProdID: 4B735EA#ABH
    OMEN by HP Laptop 17-ck040nd
    Stickers on the inside of the bottom cover:
    HT-01 E316987
    _E419 21 10 08 B4
    PA 2021.11.09.E
    MTP4DG3LBATP00
    146600YND11103A
    TFQ38G3LTP1014840023
    Many thanks in advance.
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    SN# 5CD150GBHX
    ProdID: 4B735EA#ABH
    HT-01 E316987
    _E419 21 10 08 B4
    PA 2021.11.09.E
    MTP4DG3LBATP00
    146600YND11103A
    try post #13..
    https://www.badcaps.net/forum/troubl...eo#post3304859
    • dr.thodt
      • Apr 2016
      • 87
      • Netherlands
      Originally posted by peste
      Thanks Peste,
      This bios gets the laptop to post and boot. Can you tell me the start and end address of the DMI region so I can inject this data?
      That would be the cherry on top.
      • peste
        • Dec 2016
        • 13924
        • ROMANIA
        Thanks Peste,
        DMI 701000 - 702FFF
        KEYWIN 786000 - 78603F​
        • dr.thodt
          • Apr 2016
          • 87
          • Netherlands
          DMI 701000 - 702FFF
          Thanks.
          I get a Bios CRC error 502 and it's in Manufacture Programming Mode Is In Unlock Mode. While I am probably able to fix the latter, I found out the bios is password locked. Is this password in the original's DMI area or is it in the bios you revered to? I wonder if I am able to get the CRC error out of the way.
          Some help is appreciated.
          • peste
            • Dec 2016
            • 13924
            • ROMANIA
            Thanks.
            the bios from station #13 is virgin, it has no password.. copy the DMI interval from the laptop bios to the virgin bios.. use the HxD program, put both bios into it and (copy-paste) the interval..
            • dr.thodt
              • Apr 2016
              • 87
              • Netherlands
              I injected my DMI area and key win in the areas you pointed me at. I did notice that the virgin bios was in Manufacture Programming mode unlocked. I'm not 100% sure I saw the crc error 502 with the virgin. I'd have to check that. But this admin password in the bios is bothering me a bit. I'll contact the customer on that. Or I could blank it if I knew its offset.
              • cr4zychriss
                by cr4zychriss
                • Rebrand: PC Specialist
                11-14-2025, 04:04 PM
              • Rox de guzman
                HP OMEN 17-ck0048tx — BIOS Request — RTX3060 + QHD 165Hz — DA0G3LMBCF0 Rev F
                by Rox de guzman
                I’m repairing an HP OMEN 17-ck0048tx with motherboard DA0G3LMBCF0 Rev F.
                GPU is RTX 3060 (GN20-E7-A1)
                Panel is 17.3" QHD 2560×1440 165Hz (M57128-001)
                CPU is Intel i7-11800H.
                Original fault: laptop powers on, but no display.
                With RAM installed: fans spin continuously, no keyboard, no display.
                With RAM removed: CapsLock blinks 3 slow + 2 short (RAM error), confirming POST execution.
                I have:
                ✔ Original 16MB BIOS dump
                ✔ EC (W25Q80) dump
                ✔ HP SoftPaq sp162936.exe
                Today, 08:21 PM
              • JoWed
                Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                by JoWed
                Hello Community,
                I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                07-01-2025, 09:32 AM
              • istvanszasz99
                Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                by istvanszasz99
                Product Name: Razer Blade 15 (2022)
                Product ID: RZ09-0421
                Motherboard: CH580
                BIOS Versions I work with: 2.02 & 2.06
                Bios File Size: 32,768 KB
                Dear Forum Readers!
                I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                !!! MY RAZER BLADE...
                11-24-2025, 05:52 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
