Asus Notebook GA401I, GA401 IV-BR9N6 bios needed
  • zdargh
    Osh
    • Jun 2024
    • 10
    • usa
    Hello! After an automatic windows update - it went through a bios update that has put my laptop into a boot loop that gets shorter and shorter until it just powers on and off. I can make it almost to the login screen and I tried to start the factory reset, but it just keeps entering the bootloop.
    It completely bricked at some point, so I pull the bios, but I couldn't get the DMI and windows key information to build a new one (I tried one of the guides and I can't find it), I ended up just flashing it with the ezupdate file from the asus website using a ch3a1a SPI programmer (also read the bios with this) and it actually got it out of the bricked state, but back to the progressively shorter boot loop.
    I think if someone could build a working bios for me, that would solve the issue and I would be eternally thankful! I'm so tired of working on this thing.
    Some other notes: I had a local shop fix it before from this same problem, but the hdmi port wasn't working after they flashed it, so I let it update to the newest bios version (220) and here we are.
    S/N: L5NRKD003713194
  • volinakis
    • Jan 2021
    • 2734
    • N/A
    try. It seems you are using wrong bios update, from GA401IH platform.
    • zdargh
      Osh
      • Jun 2024
      • 10
      • usa
      I flashed this one and it's the same thing, it'll act normal for about a minute and then go into a boot loop, each boot getting shorter and shorter until it's just a black screen but "on"
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • exerion5000
        Bios Needed For Asus X515EA Pcb X415EA R2.0
        by exerion5000
        Asus X515EA_No Power_GD25B127D@SOIC8.rar
        Hi Everyone! , i need repair the original bios corruptes of this model machine (Bios Needed For Asus X515EA Pcb X415EA R2.0) , the unit no power on , i test several bios for this model with some issues maybe related to especific version (keyboard partially work or no work , SSD no detected ,Etc ) so y let more data below if help , many thanks in advance!...
        02-17-2025, 01:34 PM
      • lrouw84
        by lrouw84
        Hi there,
        01-28-2023, 01:31 PM
