how to determine if my bios is faulty or corrupted
  • ry x hunter
    • Jun 2013
    • 184
    • philippines
    hello bad caps member i have a problem with acer aspire one d270..
    the problem is no power.. i check a lot of capacitor and mosfet but dont see any problem..
    i check the bios ic (winbond) brand and i found that only pin 8 has voltage reading 3. volts but other pin has no respond.. can u give me an advice if this is a bios problem?
    thanks a lot...
  • dj_ricoh
    • 2073
    Re: how to determine if my bios is faulty or corrupted
    Charging circuit is ok?
    If i do remeber i reflow a board like that and it came alive
    • ry x hunter
      • Jun 2013
      • 184
      • philippines
      yes sir charging circuit is ok.. what part did u reflow sir?
      • dj_ricoh
        • 2073
        can`t remember! 2 years ago.
        it has that stupid CPU soldered to the board
        • lezsimply
          The Wanderer
          • 645
          • Philippines
          try removing bios chip then measure the trace on pins 3,7 and 8. not the bios chip.
          • ry x hunter
            • Jun 2013
            • 184
            • philippines
            i try to remove bios ic sir and i measure it but only pin number 8 measured 3v.. pin 3,7 has no response.. no voltage reading
            • Galileo Figaro
              • Feb 2014
              • Sweden
              thanks a lot...
              Here's something I wrote to myself in the Acer Aspire One AOA 150 project folder on my HDD, maybe it will give you a pointer:
              Format a regular USB stick, one without SD converter,
              built in MP3 player etc, with the FAT file system,
              not FAT32. You will have better luck with a smaller
              one, up to 2GB.
              Download the latest BIOS for your model at Acer's support sirte.
              Rename the BIOS file, which ends in ".fd" to ZG5IA32.FD.
              Copy the file ZG5IA32.FD to the USB stick.
              Put the stick into the Acer Aspire One AOA 150,
              or AOA 110. Any USB port will do. Make sure your
              stick is the only thing attached to any USB port on
              your netbook.
              With your left hand press and hold down simultaneously
              the Fn + Esc keys. At the same time, with your right
              hand, press and hold down the power button until the
              power light starts blinking.
              When it does you can release both hands.
              It will take a while for the BIOS to get flashed and
              then the netbook will reboot.
              Hopefully everything will turn out nice and dandy.
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3582
                • slovakia
                its working only on ZG5
                • atsio
                  • Oct 2013
                  • 819
                  • Greece
                  thanks a lot...
                  On spi BIOS usually you have 3.3v on pin 1 and 8. In your case you must have 3.3 volts on pin 1 (except the resistor is missing). Bios we'll not have any voltage (and signals) if KBC is not functioning. You can see some voltage on other pins i.e. 0.5 volts, going up and down when you plug in power supply. The only way to check those pins is with an oscilloscope because they are data pins.
                  For KBC to function (like any IC) needs three signals. Power, Clock and RST. If all three signals are there (on KBC) and there is no communication with SPI probably problem with KBC. If there are no data signals on LPC between south and KBC the problem maybe the Southbridge.
                  • alihomee
                    • Dec 2012
                    • 1574
                    • malaysia
                    check 3v and 5v supply
                    • MDY
                      • Jan 2014
                      • 75
                      • Spain
                      Why do you think so? 3V Always goes to Bios and KBC at the same time, right? If KBC doesnot work, Bios still recive 3V I think. (Except when KBC has short and this voltage goes to 0V)
                      • atsio
                        • Oct 2013
                        • 819
                        • Greece
                        Pin 1 (CS)
                        • MDY
                          • Jan 2014
                          • 75
                          • Spain
                          Can you explain with more details please what do you mean with Pin 1 (CS)??
                          • rtstorm
                            • Feb 2012
                            • 971
                            • Croatia
                            i think the safe way to tell if your BIOS ic is bad to desolder it and test over some universal programmator. Than you can red data from bios and compare it with original .bin file.
                            ...the quieter you become the more you are able to hear...
                            • trebo
                              • 514
                              • Wales, UK
                              I like that idea, will be giving that a try when the opportunity arises
                              • macabook
                                by macabook
                                🧩 Initial Issue
                                Yesterday, 02:17 PM
                              • TylerHyde21
                                Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
                                by TylerHyde21
                                Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
                                I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
                                I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
                                This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
                                06-29-2024, 10:38 AM
                              • Loli Popu
                                DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                                by Loli Popu
                                Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                                12-13-2024, 08:29 AM
                              • Ugur87
                                Need Bios or Help for Corrupted Bios.bin XPlus Series 81
                                by Ugur87
                                Hello
                                ive got a brand new Xplus Series 81 mini Notebook, but its not turning on, my friend take it and make something with it, everthing looks fine , charging , power input perfect , fans spinning but no image, now i read the bios chip with ch341a programmer, i think its corrupted, is there any way to fix a corrupted bios bin ? please help...
                                07-14-2025, 06:41 PM
                              • Vesko356
                                by Vesko356
                                08-11-2023, 03:27 AM
