Dell Inspiron 5515 bios need
  • LordJohn Buo
    • May 2024
    • 5
    • Philippines
    #61
    Thank you versy much sir!. The unit now has turned on and I added the service tag. Thank you very very much.
    • piszpunta
      • Jan 2019
      • 260
      • poland
      #62
      Inspiron 5515
      ​Service Tag: 2RXXVG3
      motherboard 203076-1
      black screan
      • wzamoyski
        • Mar 2022
        • 28
        • Poland
        #63
        Inspiron 5515
        Service Tag: 5Z74KG3
        Power on, black screan
        • danito
          • Jun 2016
          • 1303
          #64
          Originally posted by piszpunta
          Inspiron 5515
          black screan
          try post 60
          • danito
            • Jun 2016
            • 1303
            #65
            Originally posted by wzamoyski
            Inspiron 5515
            try post 60
            • wzamoyski
              • Mar 2022
              • 28
              • Poland
              #66
              Works, but I need WK from old BIOS, if available.
                • 22424
                Key added.
                • trepachka
                  • Oct 2022
                  • 468
                  I can confirm the bin file in post 39 works fine. I just used it on an Inspiron 5515 machine with corrupted bios and computer is working now.
                  Upon initial boot, you will be asked to enter service tag# (ignore for now the high-pitch tactile sound every time you press any key) after which you need to go to bios and pick the correct model either Inspiron 5415 or 5515. Next boot, hit Fn-X combo to get rid of that high-pitched tactile sound. Done
                  • mferna14
                    • Jun 2018
                    • 1053
                    Hi Friends., can anyone re-build this BIOS & make the required changes. I tried the Bin files on Post #60 & my laptop gave good display & boots up too. The only reason I am getting the Bitlocker screen is due to the serial # & asset tag # & also shows Model shows as Inspiron 5415. The fan is evening spinning fast & the keyboard beeps when any key pressed. Uploaded the Original BIOS. Thanks in advance
                    Dell Inspiron 5515 Motherboard # 203076-1
                    Service Tag: F8MLQ93 Express Service Code: 33173429799
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12520
                      #70
                      I
                      nspiron 5515
                      Service Tag: F8MLQ93​
                      • grenadyr08
                        • Aug 2021
                        • chelyabinsk oblast
                        #71
                        Inspiron 5515
                        Service Tag: GZQRTG3
                        Power on, black screan​
                        • osman68i
                          • May 2015
                          • 359
                          • The Netherlands
                          #72
                          https://www.badcaps.net/filedata/fetch?id=3548909
                          you can try this bios
                          • mferna14
                            • Jun 2018
                            • 1053
                            Originally posted by hoaca388
                            I
                            nspiron 5515
                            Dear hoaca388., I programmed the BIN file you re-build for me on Post #70, but NO DISPLAY. But the one which is on Post #60​ works 100% fine on my laptop but it goes to BitLocker because the serial # is incorrect. Can you please re-do the bin file again, maybe need a bit tweaking, thanks in advance.
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12520
                              #74
                              Dear hoaca388., I programmed the BIN file you re-build for me on Post #70, but NO DISPLAY. But the one which is on Post #60 works 100% fine on my laptop but it goes to BitLocker because the serial # is incorrect. Can you please re-do the bin file again, maybe need a bit tweaking, thanks in advance.
                              Vostro 5515
                              • mferna14
                                • Jun 2018
                                • 1053
                                Vostro 5515
                                Dear hoaca388., good day.... This BIOS Update even did not work. But anyway what I did is, used the working BIOS on Post #60, replaced the serial # & the Model through HxD, where exactly these Hex Values have to be written. All worked fine & serial # even update. Thanks dear for all your help. I know YOU put a lot of effort to help us all. HIGH HATS TO YOU hoaca388, really appreciate!!!
                                • gadgetresQ
                                  • Aug 2024
                                  • 12
                                  • philippines
                                  #76
                                  hello pls repair my bios
                                  inspiron 5515
                                  service tag G390QG3
                                  • Thang Nguyen 12380
                                    Thang Nguyen
                                    • Mar 2025
                                    • 23
                                    • Vietnam
                                    #77
                                    Hello everyone, I have the laptop of unknown model (may be Inspiron 5515) with cpu amd R5-5500u. When i press power button, the keyboard light up but no display, Anyone have bios file for this motherboard, or can help me build this bios.
                                    This is the bios file i backed up from motherboard
                                    ST: 6NT0DL3
                                    Many thanks
                                    • quocdan7
                                      • Aug 2024
                                      • 10
                                      • Việt Nam
                                      #78
                                      ST: 6NT0DL3
                                      Many thanks
                                      try this file​
                                        Thang Nguyen
                                        • Mar 2025
                                        • 23
                                        • Vietnam
                                        #79
                                        Originally posted by quocdan7
                                        try this file​
                                        It works, thank you very much
                                        • suptec
                                          • Oct 2024
                                          • VietNam
                                          #80
                                          Inspiron 5515
                                          Service Tag: 3BWRDL3
                                          hi all, please, can someone provide me with the BIOS for my Dell Inspiron 15 5515. It has no screen, a lit keyboard, and a spinning fan.
                                          My Service Tag: BNYGJG3
                                          • capoplays
                                            Help with BIOS update on Dell G15 5515 after chip replacement
                                            by capoplays
                                            Hey everyone,
                                            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                            When I check the BIOS using the F12 menu Flash...
                                            10-24-2025, 06:53 AM
                                            DELL Inspiron 5515 Notebook 5000 Specification for Upgrade or Repair
                                            This specification for the DELL Inspiron 5515 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5515 boardview and 5515 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 5515...
                                            09-07-2024, 02:00 AM
                                            09-07-2024, 01:00 AM
