I got a new EC chip cause old one was shorted but I need to reprogram it somehow. I got the chip and the programmer/reader. I also trying to figure out where to hook up the wires for the programmer. It says to connect to SM bus on motherboard . Any help is appreciated.
Razer Blade 15 RZ09-0369. Looking for help with XZZ ITE programmer ?
XZZ ITE Programmer For Macbook Lenovo Intel Laptop without disassembly ITE85XX ITE83XX IT8390 EC Read Write Chip Process Tool.Link: https://lnkd.in/dm4HGkEd#...Tags: None -
Thank you !!!Comment
Link doesn't work anymore, please send if possible.Comment
here it is
Attached Filesif you find these attachements useful please consider making a small donation to the site
Here you go ver 4.0.1.0
Here is version 4.0.1.0Attached Filesif you find these attachements useful please consider making a small donation to the site
This programmer seems to use ITE DBGR interface over I2C/SMBus. There's no documentation available but there is some code:
iteflash: https://chromium.googlesource.com/ch...ec/+/HEAD/util
I2ITE: https://github.com/c0d3z3r0/i2ite
Both are using FTDI chips so there's no need for a special programmer.
Seems that the DBGR interface is activated by sending some magic (not valid I2C) data to the EC. Then it works like a regular I2C device, supporting both reading and writing the flash.Comment
hi, i recently wandering around to read this kind of info. if the FT232H is used in the I2ITE, the codezero also write for reading ENE one. the FT232H is just basically usb to i2c devices right? so is it possible to use ch341a which have capability to do i2c communication to read/write ITE ec chip with correct coding/programming?This programmer seems to use ITE DBGR interface over I2C/SMBus. There's no documentation available but there is some code:
Hello! I have a Lenovo Z510 AILZA NM-A181 laptop The IT8586E multicontroller burned down I replaced it, ordered this programmer XZZ IT8390 programmer, and downloaded the app for it. But, I can't find the schematics for this laptop, and I can't figure out where to connect this programmer, there are only 4 GND 3 pins.3V SDA SCL Please tell me what to do..Comment
Can the RT809H read and write the IT8227E-256?
I have a ThinkPad E14 GEN3, and I saw that it unlocks using the EC, which is located in the ITE (the chip silkscreen says LENOVO).
Does anyone know if they've been able to do it using this tool?
I only have the T48 and CH341, so there's no way for them to unlock the IT8227E-256?Comment
Hi, everyone!
I've a Razer Blade 2020 on my bench today, all stand-by tensions are OK, but we've no action when I press the power button.
Here's some informations about the laptop and the original file backup:
Laptop Model: Razer Blade 2020
MB Model: ol510mb v1.0
P/N: RZ09 03519E11
S/N: 622048M10000619
Many thank's in advance! And if I broke any rule, sorry, I'm a rookie here, just tell me how can I fix that
Channel: BIOS Requests ONLY!
Product ID: RZ09-0421
Motherboard: CH580
Bios File Size: 32,768 KB
Dear Forum Readers!
!!! MY RAZER BLADE...-
11-24-2025, 05:52 PM -
by theplopRazer blade 2022, 14" PI480, Ryzen 6900HX, 16gb ram
I picked up a Razer blade 14" (2022) from a friend who said it "overheated" and he replaced one of the fans. He gave up on it as windows wouldn't work/re-install. He gave it to me, and i've been working on getting linux on it. Installing Mint i was able to get about 1/4 through the installer before it froze. Now i can't even get the installer to boot. I am met with a kernel panic.... sometimes. Sometimes it just hangs on the boot sequence.
I've run memtest quite a few times, and more often then not...4 Photos -
by shellybellyBack Story
I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be... -
by AwdevS/N is BY2011A72401766
Full name: RZ09-03006E92-R3U1 Razer Blade 15” (2019) | RZ09-03006
MB Model is: DA530-MB
Dump is below, Laptop can do EC Reset but cannot boot. Suspect its BIOS or EC....-
- Loading...
