Razer Blade 15 2022, No internal display, Error Code 43
  • Rangry
    • May 2025
    • Spain
    Hi! I have a Razer Blade 15 2022, with a RTX 3060.
    One day, while using Linux, the internal display suddenly stopped working.
    On Windows, it says that the internal GPU has stopped working (with error code 43).
    I have tried removing the coin cell and the battery, and replacing the RAM, with no success on fixing anything.
    I'm looking for directions to fix this problem, and, first of all, I would like to be able to access the BIOS and change some settings (which is currently impossible as it is always shown on the internal display). There is a setting that allows running only on the Nvidia GPU that I would like to enable as it should allow me to see the BIOS screen.
    Any help is welcome! And thanks in advance!
  • lanovey
    SF314-41 BIOS without internal display
    by lanovey
    Hello there,
    I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
    I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle...
    06-13-2025, 02:38 AM
  • theplop
    Razer blade 2022, 14" PI480 wont boot to OS, freezes
    by theplop
    Razer blade 2022, 14" PI480, Ryzen 6900HX, 16gb ram
    I picked up a Razer blade 14" (2022) from a friend who said it "overheated" and he replaced one of the fans. He gave up on it as windows wouldn't work/re-install. He gave it to me, and i've been working on getting linux on it. Installing Mint i was able to get about 1/4 through the installer before it froze. Now i can't even get the installer to boot. I am met with a kernel panic.... sometimes. Sometimes it just hangs on the boot sequence.
    I've run memtest quite a few times, and more often then not...
    03-20-2025, 06:42 PM
  • plyanthony
    Razer Blade 15 no external display with attached screen disconnected from motherboard
    by plyanthony
    Computer in question : Razer Blade 15 2020 Base Model
    Model# RZ09-03286E22
    BIOS CHIP: WINBOND W25Q128BV
    What I'm trying to accomplish:
    I want the computer to properly boot with an external display with the attached display disconnected from the motherboard. I have a CH341A programmer and full capability of modifying the BIOS easily. I Have tried various setting changes to no Avail.
    What I've tried thus far: Too much to note and I really dont remember everything I changed but here it goes.
    W/Stock BIOS - 1.06:
    Disconnect the...
    02-01-2023, 09:35 PM
  • pepebmx
    RAZER BLADE advanced 2022 rtx 3080 no post/display rz09-0409cec3
    by pepebmx
    Hi guys, i just got a brand new razer blade 15 rz09-0409cec3 that turns on keyboard light, fans but no display at all. I managed to get bios bin file from razer but im not sure if this chip is THE bios chip. It is a Gigadevice 25q64cig (Uee704 Aj2103) or something like that. I believe that is the bios chip, I uploaded photos from all of them in case i am wrong. https://drive.google.com/drive/folde...9M?usp=sharing If its ok i will remove it, read it with ch341A , backup and share bios file here so you can check what is wrong. I will try to flahs bios bin file from...
    03-15-2022, 12:14 PM
  • Giggle2562
    Lenovo V15-IIL motherboard swap (in V15-IKB) shuts down when internal display is connected
    by Giggle2562
    I have a Lenovo V15-IKB that had a damaged motherboard. I replaced it with a motherboard from a Lenovo V15-IIL.
    The board powers on, but it shuts down after about 10-15 seconds. This only happens when the internal display (LCD panel) is connected.
    Here's what I've tried so far:
    • When the internal display is disconnected, the laptop works perfectly fine via HDMI.
    • The laptop shows an image on the internal display for a few seconds before it shuts down.
    • I tried swapping the LCD panel with a known good one.
    • I tried swapping the LCD cable
    11-06-2025, 12:36 PM
