I got a new EC chip cause old one was shorted but I need to reprogram it somehow. I got the chip and the programmer/reader. I also trying to figure out where to hook up the wires for the programmer. It says to connect to SM bus on motherboard . Any help is appreciated.
Razer Blade 15 RZ09-0369. Looking for help with XZZ ITE programmer ?
XZZ ITE Programmer For Macbook Lenovo Intel Laptop without disassembly ITE85XX ITE83XX IT8390 EC Read Write Chip Process Tool.Link: https://lnkd.in/dm4HGkEd#...Tags: None -
here it isAttached FilesComment
This programmer seems to use ITE DBGR interface over I2C/SMBus. There's no documentation available but there is some code:
iteflash: https://chromium.googlesource.com/ch...ec/+/HEAD/util
I2ITE: https://github.com/c0d3z3r0/i2ite
Both are using FTDI chips so there's no need for a special programmer.
Seems that the DBGR interface is activated by sending some magic (not valid I2C) data to the EC. Then it works like a regular I2C device, supporting both reading and writing the flash.Comment
Hello! I have a Lenovo Z510 AILZA NM-A181 laptop The IT8586E multicontroller burned down I replaced it, ordered this programmer XZZ IT8390 programmer, and downloaded the app for it. But, I can't find the schematics for this laptop, and I can't figure out where to connect this programmer, there are only 4 GND 3 pins.3V SDA SCL Please tell me what to do..Comment
Can the RT809H read and write the IT8227E-256?
I have a ThinkPad E14 GEN3, and I saw that it unlocks using the EC, which is located in the ITE (the chip silkscreen says LENOVO).
Does anyone know if they've been able to do it using this tool?
I only have the T48 and CH341, so there's no way for them to unlock the IT8227E-256?Comment
by theplopRazer blade 2022, 14" PI480, Ryzen 6900HX, 16gb ram
I picked up a Razer blade 14" (2022) from a friend who said it "overheated" and he replaced one of the fans. He gave up on it as windows wouldn't work/re-install. He gave it to me, and i've been working on getting linux on it. Installing Mint i was able to get about 1/4 through the installer before it froze. Now i can't even get the installer to boot. I am met with a kernel panic.... sometimes. Sometimes it just hangs on the boot sequence.
I've run memtest quite a few times, and more often then not...4 Photos -
by shellybellyBack Story
I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be... -
by TrodrigueHi everyone, I'm posting this message for help. I was given a Razer Blade motherboard because many people around me know that I like to tinker or make things with computer salvage.
The problem with this board is that the person ripped out the keyboard port from the board.
But in short, it's not a problem in itself because I'm planning to build a console with this motherboard.
The problem is turning on the card without the keyboard.
So I'm looking for another way to turn it on, either by
using the pins or by using the ITE chip ref: IT8320VG-256 1920-DX0 EA07ZB....10-02-2025, 10:17 AM -
by bumper1Razer Blade 15 RZ09-0328
MOBO: DA550-MB MP V4.0 20200227-
Channel: Schematic Requests ONLY!
07-10-2025, 03:40 AM -
by bumper1I have Razer Blade 15 RZ09-0328 MOBO: DA550-MB MP V4.0 20200227 with liquid damage.
I need to know value of resistor on photo. Thanks for help. ... - Loading...
