Looking for schematic or bv for Razer Blade 15 RZ09-0328 MOBO: DA550-MB
  • bumper1
    • Jul 2014
    • 77
    • Poland
    MOBO: DA550-MB MP V4.0 20200227
  • theplop
    Razer blade 2022, 14" PI480 wont boot to OS, freezes
    by theplop
    Razer blade 2022, 14" PI480, Ryzen 6900HX, 16gb ram
    I picked up a Razer blade 14" (2022) from a friend who said it "overheated" and he replaced one of the fans. He gave up on it as windows wouldn't work/re-install. He gave it to me, and i've been working on getting linux on it. Installing Mint i was able to get about 1/4 through the installer before it froze. Now i can't even get the installer to boot. I am met with a kernel panic.... sometimes. Sometimes it just hangs on the boot sequence.
    I've run memtest quite a few times, and more often then not...
    03-20-2025, 06:42 PM
  • shellybelly
    Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
    by shellybelly
    Back Story
    I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
    So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
    08-27-2023, 10:40 PM
  • Rangry
    Razer Blade 15 2022, No internal display, Error Code 43
    by Rangry
    Hi! I have a Razer Blade 15 2022, with a RTX 3060.
    One day, while using Linux, the internal display suddenly stopped working.
    On Windows, it says that the internal GPU has stopped working (with error code 43).
    I have tried removing the coin cell and the battery, and replacing the RAM, with no success on fixing anything.
    I'm looking for directions to fix this problem, and, first of all, I would like to be able to access the BIOS and change some settings (which is currently impossible as it is always shown on the internal display). There is a setting...
    05-29-2025, 07:01 AM
  • vinaypundith
    Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
    by vinaypundith
    I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
    So, I'm looking for a BIOS dump for this machine - a 16MB one....
    08-03-2024, 12:32 PM
  • Pawel Borowski
    Solving Razer Blade 14 (2022) RZ09-0427 from scrap.
    by Pawel Borowski
    Hi folks,
    I want to solve a Razer Blade 14 (2022) RZ09-0427 with Ryzen 9 6900HX and RTX 3070Ti from scrap, and I need your help with the diagnosis.
    I have checked (I hope) all the voltage rails and found no shorts to GND and B+ except for the CPU VDDCR_SR rail (see the photo), which is near zero ohms to GND.
    When plugged to PS, the laptop charges the battery, and after pressing start, it supplies voltage to all voltage rails except for CPU VDDCR_SR one and, of course, the dGPU, nothing more.
    I have no experience in this type of repair, so please let me know if the low resistance...
    05-05-2025, 07:37 AM
