Razer Blade 15 RZ09-0369. Looking for help with XZZ ITE programmer ?
  • chickenhawk88
    • May 2024
    • 86
    • US
    I got a new EC chip cause old one was shorted but I need to reprogram it somehow. I got the chip and the programmer/reader. I also trying to figure out where to hook up the wires for the programmer. It says to connect to SM bus on motherboard . Any help is appreciated.
    Click image for larger version  Name:	Screenshot 2024-06-04 173121.png Views:	8 Size:	215.1 KB ID:	3284149
  • alfredposadas09
    • Aug 2020
    • 343
    • Philippines
    connect CLK to CLK and DAT to DAT and Ground to Ground to the battery terminal
    • chickenhawk88
      • May 2024
      • 86
      • US
      Thank you for response, i dont have schematic or pinout of the EC chip so cant find it on board.
      • asmedia
        • Mar 2023
        • Ukraine
        Hello, where can I get the program?
        • chickenhawk88
          • May 2024
          • 86
          • US
          https://www.ite.com.tw/uploads/produ...0.8_Beta02.zip
          • asmedia
            • Mar 2023
            • Ukraine
            Originally posted by chickenhawk88
            Thank you !!!
            • ken0011
              • Nov 2018
              • 11
              • 3W
              can you send me the software? the link doesn't work. I am looking at iteec_winflash 4.0.1.0
              • Beertimenow
                • Mar 2020
                • 21
                • United Kingdom
                Link doesn't work anymore, please send if possible.
                  • 20745
                  here it is
                  • mataj
                    • Mar 2024
                    • Slovakia
                    normally pin 4 is smbus clock and pin 5 is smbus data on battery connector
                    • mataj
                      • Mar 2024
                      • Slovakia
                      anybody can upload software iteec_winflash 4.0.1.0​?
                      version 4.0.1.0 please
                      • chickenhawk88
                        • May 2024
                        • 86
                        • US
                        Originally posted by mataj
                        anybody can upload software iteec_winflash 4.0.1.0?
                        Here you go ver 4.0.1.0
                        Here is version 4.0.1.0
                        Last edited by SMDFlea; 09-30-2024, 03:01 AM. Reason: Added attachment to post from external link..
                        • Rainbow
                          • Aug 2005
                          • 1371
                          This programmer seems to use ITE DBGR interface over I2C/SMBus. There's no documentation available but there is some code:
                          iteflash: https://chromium.googlesource.com/ch...ec/+/HEAD/util
                          I2ITE: https://github.com/c0d3z3r0/i2ite
                          Both are using FTDI chips so there's no need for a special programmer.
                          Seems that the DBGR interface is activated by sending some magic (not valid I2C) data to the EC. Then it works like a regular I2C device, supporting both reading and writing the flash.
                          • blackbirdrepairshop
                            • Feb 2023
                            • Philippines
                            HOW TO PROGRAM BIOS CHIP USING XZZ PROGRAMMER?
                            • ndarjo21
                              • Nov 2021
                              • 77
                              • Indonesia
                              hi, i recently wandering around to read this kind of info. if the FT232H is used in the I2ITE, the codezero also write for reading ENE one. the FT232H is just basically usb to i2c devices right? so is it possible to use ch341a which have capability to do i2c communication to read/write ITE ec chip with correct coding/programming?
                              • ndarjo21
                                • Nov 2021
                                • 77
                                • Indonesia
                                after talking with imsprog maintainer, it seems the ch341a unable to send the initial waveform to make the EC get into debug/DFU mode because the in gpio mode, it will be very slow in ch341a sda and scl
                                • ZeN_
                                  • Mar 2025
                                  • Russia
                                  Hello! I have a Lenovo Z510 AILZA NM-A181 laptop The IT8586E multicontroller burned down I replaced it, ordered this programmer XZZ IT8390 programmer, and downloaded the app for it. But, I can't find the schematics for this laptop, and I can't figure out where to connect this programmer, there are only 4 GND 3 pins.3V SDA SCL Please tell me what to do..
