HP Elitebook 650 G10
  • astra45
    • Jan 2025
    • 11
    • Ukraine
    #41
    I recorded your dump into the chip again, but when I turn it on, the message appears: "The BIOS has recovered its identity data from the Embedded Controller due to data mismatch." Help please.
    • YOUNES MIH
      • Nov 2017
      • 45
      • ALGERIE
      #42
      remove password plz
      HP EliteBook 650 g10
      cm: da0x8tmb8e0
      sn: 5CD3294NKN
      • rex98
        • Feb 2023
        • 1278
        • Mandaue CEBU, Philippines
        #43
        i noticed there's a lot of unlock request for this model HP Elitebook 650 G10 and patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you should flash both.
        first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
        use BCU....
        • astra45
          • Jan 2025
          • 11
          • Ukraine
          #44
          use BCU....
          Can I use these files for my laptop?
          • rex98
            • Feb 2023
            • 1278
            #45
            yes as long as its 650 g10
            • YOUNES MIH
              • Nov 2017
              • 45
              • ALGERIE
              #46
              Originally posted by YOUNES MIH
              remove password plz
              cm: da0x8tmb8e0
              sn: 5CD3294NKN
              remove password plz
            • astra45
              • Jan 2025
              • 11
              • Ukraine
              #47
              Thank you! The password has been reset.​
              • ghedada.06
                • Feb 2023
                • 16
                • Algeria
                #48
                Rex98 thank you very much!! Really appreciate taking time to help us 🫡
                • hpboy
                  • Jan 2021
                  • 53
                  Hi All,
                  Please could someone help remove the admin bios password on my Elitebook 650 G10?
                  Serial - 1H8416018Y
                  ProdID - 736X4AV
                  Model - HP Elitebook 650 G10
                  I have tried RCUnlocker but the generated _unlocked file does not work.
                  Attached is the BIOS image (from the main IC, not the EC IC - is that correct?)
                  Thank you very much
                    SMDFlea commented
                    Editing a comment
                    Thread merged.
                • lapfix
                  • Mar 2020
                  • 2729
                  • my workshop
                  #50
                  Originally posted by hpboy
                  Hi All,
                  Serial - 1H8416018Y
                  ProdID - 736X4AV
                  Thank you very much
                  Try post #43
                  • hpboy
                    • Jan 2021
                    • 53
                    Originally posted by lapfix
                    Try post #43
                    Thank you - trying to download but errors with "Invalid File Specified" Can some please re-upload "HP Elitebook 650 G10 CLEAN UNLOCKED.rar"?
                    • hpboy
                      • Jan 2021
                      • 53
                      use BCU....
                      rex98 - please can you re-upload? Link in Post 43 errors withi invalid file
                      • lapfix
                        • Mar 2020
                        • 2729
                        • my workshop
                        #53
                        Rex98 files
                        • hpboy
                          • Jan 2021
                          • 53
                          Rex98 files
                          Amazing.. worked like a charm. Thank you very much.
                          Out of interest, I did not need to flash the EC image, just the main bios file. F10, reset all settings, laptop rebooted a few times and went into recovery mode, but then all working and bios password removed! Thank you
                          • nemogoce
                            • Nov 2023
                            • Slovenia
                            #55
                            Hi all, I would ask for some help/advice. I followed Rex98 instructions and the laptop booted as expected with no password. When applying BCU settings I figured out that I also needed board CT so I shut down the laptop which was running on adapter with battery and 3.3 battery plugged off. I removed the RAM to take a picture of the CT number and then replaced the RAM, plugged in the wi-fi card then the 3.3 and then the battery since I figured I can close the lid. I booted the laptop, the hp logo showed for about 10 s and then it shut down again. Now every time I try to turn it on I first get blinking num lock and f5 and f7 keys (5 times) and after this 7 simultaneous blinks of num lock and caps lock (BIOS issue). I tried reflashing both main BIOS and EC but nothing changes. Any ideas what could it be?
                            Also the MTM counter was at 1 before last shut down.
                            UPDATE: For some reason after I gave it another try, the laptop turned on, I got into bios, set factury defaults, and after the reset the situation is the same as described. I don't consider myself a beginner but this has got me stumped.
                            • rex98
                              • Feb 2023
                              • 1278
                              #56
                              This is the update it works in 3 models they have the same bios but different BID
                              I noticed there's a lot of unlock request for this model HP EliteBook 630,640,650 v75 & V74 G10
                              The patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you should Flash Both.
                              use BCU and put your original DMI
                              This bios is extracted from hp website so its fast boot this would work in 3 models 13, 14 and 15 inch they have the same bios.
                              To determine your BID use any hex editor and search for the BID. Ex: V75
                              frequently asked questions:
                              can i use this to myHP EliteBook 630,640,650 v75 & V74 G10- yes
                              This is the both BID V74 and V75 its all you need.​
                              To determine your original DMI use my DMI tool: https://www.badcaps.net/forum/troubl...57-hp-dmi-tool
                              • Max Leo
                                • Sep 2024
                                • 4
                                • belgium
                                #57
                                this not work for me please patch this
                                Serial Number: 5CG3333MZ6
                                Product #/SKU : 6T2B6EA#UUG
                                CT Number: PRTRU00WBIG3ZQ
                                Description: HP EliteBook 840 14 inch G10
                                BuildID: 23WWWGBZ601#SUUG#DUUG
                                Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAfPguhKhkjhk8mEmGn7nVngpDpTpWpnpppqprqMqkqz.Dh
                                MAC Address : 64:4E7:51:58:67​
                                  HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                                  This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                  09-07-2024, 05:50 AM
                                  HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                  This specification for the HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 650 15.6 inch G9 Notebook PC boardview and EliteBook 650 15.6 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                  09-07-2024, 05:20 AM
                                  HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                  This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
