Bios repair Lenovo NM-D711 rev 2.0
  • A1yn88
    • Mar 2014
    • 111
    • Romania
    Hello.
    I need help with a bios repair Lenovo NM-D711 rev:2.0, SN:PF2RCN2A. Problem: Black screen.
    Thank you.​
  • hoaca388
    Badcaps
    • Jan 2022
    • 12406
    Originally posted by A1yn88
    Hello.
    Thank you.
    Legion 5 Pro-16ITH6H Laptop (Lenovo) - Type 82JD
    • echothegamer
      • Oct 2023
      • 15
      I also need assistance with Legion 5 Pro bios no post/black screen issue.
      Lenovo NM-D711 (rev unknown)
      SN: PF33Y1Z6
      Thank you in advance. ​
      • hoaca388
        Badcaps
        • Jan 2022
        • 12406
        SN: PF33Y1Z6
        Backup 16MB chip
        • echothegamer
          • Oct 2023
          • 15
          Hello Hoaca388,
          Just so I understand, I uploaded a rar back up of the 8mb winbond bios chip in my initial post. Is there another 16 mb chip potentially under the heatsink that I need to make a back up of?
          I was trying not to dissemble since it is still under warranty. I planned to reflash original bios if these methods failed when warranty restarts. I’m very new to this and was only aware of one chip to flash. Clearly this could be more complicated than I was aware.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12406
            Hello Hoaca388,
            This model's bios is divided into 2 parts: 8MB and 16MB. The 16MB file contains your DMI.
            • echothegamer
              • Oct 2023
              • 15
              On second thought and a google search, I have no idea what that person is taking about. That seems like a ship they are referencing not a software lol. So I'm not sure if I need another reader or another software. I believe my drivers are up to date on my CH341A.
              It seems they were suggesting I use the CH341A and manually select the EON EN25Q128 to read the XMC QH128AHIG. I can give this a shot and see if it reads.
              I understand now. I removed the heat sink and found a chip nearby the windbond bios chip. My CH341A programmer could not read it but another thread said to install EON EN25Q12 to read the XMC chip. So I shall try that tomorrow.
              • echothegamer
                • Oct 2023
                • 15
                hoaca388
                I was able to extract the backup for 16mb XMC chip using my CH341A and manually selecting EON EN25Q128.
                I am attaching the 8mb and 16mb backups. Both were acquired w/o desoldering using the clip provided with the CH341A.
                I have heard in some cases these BIOS chips need to be desoldered to read and write properly but I am unsure if this this is the case for my particular laptop.
                Thank you for your help.
                • volinakis
                  • Jan 2021
                  • 2875
                  • N/A
                  hoaca388
                  your 16Mb dump is blank! Use AsProgrammer to read 16Mb chipset.
                  • echothegamer
                    • Oct 2023
                    • 15
                    Oh, I’m so sorry! I didn’t even think to verify the dump contents. I will download AsProgrammer and redump.
                    • echothegamer
                      • Oct 2023
                      • 15
                      I have successfully dumped the 16mb XMC chip backup and it is NOT blank this time lol. This one is labeled 2.0
                      Sorry for the delay. Turns out selecting the EON EN25Q128 did allow me to read my XMC with AsProgrammer.
                      • WTFRules!
                        • Feb 2023
                        • 31
                        • Argentina
                        Hi! I need help to know if the attached BIOS dump is OK or not, the laptop have no shorts, won´t turn on, It have voltages OK, but it don´t even light up a single LED when charger is plugged in , with or without battery connected, and when pressing POWER ON button, nothing happens. No shorts detected with thermal cammera either...
                        LENOVO LEGION 5 15ITH6H
                        S/N PF3WYXJR
                        MOTHERBOARD NM-C711 REV 2.0
                        Thanks!
                        • peste
                          • Dec 2016
                          • 13728
                          • ROMANIA
                          S/N PF3WYXJR
                          Thanks!
                          try post#2...https://www.badcaps.net/forum/troubl...mp#post1750298
                          • echothegamer
                            • Oct 2023
                            • 15
                            If someone had the time, I would really appreciate it if you could take a look at my two previously uploaded bios files. I’m not very sure how this works but I would guess that the bios is checked and then repaired if necessary. Any help or direction would be much appreciated. I can reupload them again if that’s less confusing. The first 16mp upload was blank unfortunately. The second is correct.
                            • WTFRules!
                              • Feb 2023
                              • 31
                              • Argentina
                              Originally posted by peste
                              Hey, Thanks a lot!
                              I tryed with that but the problem persists, but I was able to detect that 3V3Always is present for a couple seconds, then gone, and then coming back again in a loop, I´ll check that circuit and perhaps open a new thread in the rigt place.
                              Thanks you guys!
                              • echothegamer
                                • Oct 2023
                                • 15
                                I need assistance with Legion 5 Pro bios no post/black screen issue.
                                SN: PF33Y1Z6
                                Thank you for your help.​
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 12406
                                  SN: PF33Y1Z6
                                  • echothegamer
                                    • Oct 2023
                                    • 15
                                    After the reprogram, it posted!!! Thank you all so much for the help. It is greatly appreciated
                                    • WTFRules!
                                      • Feb 2023
                                      • 31
                                      • Argentina
                                      S/N PF3WYXJR
                                      Thanks!
                                      Hello again!
                                      I was working on this laptop, and seems I need to replace the IC IT8227E-192 CXA because it makes the +3V3ALW and +5ALW voltages come and go in a loop, not being shorted as it usually does when it gets fried. Anyways, I need the firmware to program it with, and I was reading two version on how to get it, one is to dump from the BIOS at offset 0x2C8000 lenght 0x20000 (128k), and other way is to search for "ITE" also in the BIOS and extract from it, and I get two completelly differente results from both extraction methods, so I´m lost.
                                      I´m buying the IC from Aliexpress and the seller also program it with the firmware I can provide to him, this mainboard have a i7 Intel CPU and NVIDIA GPU, also I read that if the chip is all blank, with "FFFF" it will self-program in Intel based motherboards, but this won´t happen in AMD based ones...
                                      Can someone get me the right EC firmware so I can send to the seller of the spare IC so he can program it, please?
                                      The original 16MB BIOS file read from this laptop is posted in the quoted message!
                                      Thank you!!!
                                      • peste
                                        • Dec 2016
                                        • 13728
                                        • ROMANIA
                                        Hello again!
                                        Thank you!!!
                                        bios EC extracted from bios from post#2
                                        A0000 - CFFFF 192KB
                                        • grimacelord
                                          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                          by grimacelord
                                          Hello there.
                                          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                          History:
                                          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                          I searched for this error online and discovered...
                                          03-15-2023, 03:29 PM
                                        • riko 656
                                          Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                                          by riko 656
                                          I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                                          Laptop Model:
                                          • Model: Lenovo Legion Slim 5 16APH8
                                          • GPU: NVIDIA GeForce RTX 4070
                                          • Main BIOS chip size: 32MB
                                          • VBIOS chip size: 16MB
                                          Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                                          What I Have Tried So Far:
                                          1. I
                                          11-04-2025, 05:14 AM
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                          LENOVO Legion Y720 Legion i7-7700 Specification for Upgrade or Repair
                                          This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                                          09-12-2024, 02:30 PM
