ASUS M3401QA BIOS request
  • kingblade20
    • May 2024
    • 8
    • Ireland
    My M3401QA does not power on properly: no display (all black) and with white LED charging port blinking slowly (once every ~3 seconds).
    Checked several points across the board and supplies are up and running but I need to double check when I get schematic.
    Result is still the same even with DC jack inserted and battery connector removed.
    Tried flashing the latest BIOS as of this date to no avail which I suspect has something to do with DMI but tools could not run properly on my machine and couldn't find manual copy of DMI through hex editor and not sure about the addresses involved, sorry.
    Please see attached zip for the BIOS dump before I flashed the latest manufacturer BIOS (*.bin).
    Looking forward for some assistance if someone can provide the new BIOS with DMI and other information required I may not be aware of. thank you.
    Cheers!
    • 21040
    Post the laptop serial number https://www.badcaps.net/forum/troubl...before-posting
    • kingblade20
      • May 2024
      • 8
      • Ireland
      Hi SMDFlea,
      Sorry! here's the S/N:
      N1N0CX21596203D
      • kingblade20
        • May 2024
        • 8
        • Ireland
        Hi All,
        I tried downloading the ASUS EZ flash version 308 -> extract to binary -> remove addr 0x00000000 to addr 0x000007FF -> and copy address 0x00021000 to 0x00030FFF from M3401Q_Read_05172024.bin (which I assumed to be the DMI) over to the version 308 binary. I then flashed the modified version 308 but the laptop does not boot up still.
        attaching the modified version 308.
        Can anyone help where I might've gone wrong here? Thank you
        • kingblade20
          • May 2024
          • 8
          • Ireland
          Hi All,
          Can anyone help me here? Thank you.
          • hoaca388
            Badcaps
            • Jan 2022
            • 11815
            Originally posted by kingblade20
            Hi All,
            M3401QA
            • kingblade20
              • May 2024
              • 8
              • Ireland
              Originally posted by hoaca388
              M3401QA
              Hi hoaca388,
              I believe this is the default BIOS from Asus website EZ flash version without the 0x00000000 to addr 0x000007FF, correct? I've tried flashing but result is still the same.
              Hi Luke11037 ,
              Mine blinks at a very slow rate (few seconds white LED on, few seconds off, then repeat), so it's the latter in your description.
              Could you share the boardview too? is it specific to M3401QA?
              Quite unlucky I can't run openboardview on my two other machines so far.
              • Bonebreaker777
                • Aug 2024
                Good evening to all,
                My laptop is having issues and as far as I can read, some form of BIOS flashing could resolve the issue.The laptop is not booting, tried battery reset, etc. Power LED is on, the battery LED is flashing slowly.
                Model: ASUS Vivobook Pro 14
                Exact model no.: M3401QA-KM065W
                Serial: 12M
                Motherboard: M3500QA Rev: 2.1
                Serial no.: MCN0CX034802484
                Please and thank you very much
                  • 21040
                  Serial: 12M
                  Thread merged. Do you have an SPI bios programmer
                  • isaiahpism
                    • Apr 2025
                    • 5
                    • Philippines
                    Good day, my laptop's bios got corrupted after windows update. I tried reflashing it via Ezflash however, it worsened the problem and now it wont turn on. I search for fix in asus but wont work. i dont have the dump file. My laptop won't display anything and no fan when I press the power button. Can someone please share their BIOS BIN so I can reprogram mine. Thank you so much for the help.
                    Model: ASUS Vivobook 14 Pro OLED (M3401QA)
                    Processor: Ryzen 5 (5000series)
                    Serial: MBN0CX36H72348A
                    • peste
                      peste commented
                      Editing a comment
                      post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                  • peste
                    • 12887
                    • ROMANIA
                    post the contents of the bios chip even if it is corrupted..
                    • isaiahpism
                      • Apr 2025
                      • 5
                      • Philippines
                      apparently, i can no longer do that because i tried reprogamming my bios and failed several times. is there no way to fix it? thank you so much
                        • 21040
                        Post a picture of the QR code on the motherboard, or scan it yourself and post the info.
                        • isaiahpism
                          • Apr 2025
                          • 5
                          • Philippines
                          i found this 2 QR codes in the motherboard. Not sure which one do you need.
                            • 21040
                            The serial number in the QR code is MB47NBCX00V7HDMB ,different to the one you posted, so it`s either had a replacement motherboard or the base cover is from another laptop. Try the attached bios .
                            • isaiahpism
                              • Apr 2025
                              • 5
                              • Philippines
                              Thank you for this. My laptop got revived.
                              • AJ28006
                                • May 2025
                                can someone please help to restore my BIOS which is requesting a password after an aborted windows update?
                                Model: ASUS Vivobook Pro 14 OLED (K3400PA)
                                Processor: Intel Core i5
                                Serial: N3N0CX12M012106
                                Motherboard: Not really known, please have a look to the attached QR code of the mainboard inside the zip file.
                                Many thanks in advance 😊
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11815
                                  Unlocked
                                  • AJ28006
                                    • May 2025
                                    Unlocked
                                    Again many many thanks, its working 😊👍
                                    • dinnetok
                                      • Nov 2019
                                      • Malaysia
                                      Hi. I need help to revive my laptop bios asus vivobook M3401QC. I have ch314a programmer and nothing happen when i flash the bios file from asus website. I have scan the qr and have no idea what information is that. here it is QCCXJE63A14803218,MB48NBCX010HHMMB,M3401QC,60NB0VF0-MB1020,211.
                                      Please help me provide a working bios file. Thanks
                                      • razor_amd
                                        by razor_amd
                                        12-15-2020, 07:07 PM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
                                      • throwaway327
                                        by throwaway327
                                        Model No: RC72LA
                                        Serial No: SBNVKD001014459
                                        06-18-2025, 05:52 PM
                                      • lrouw84
                                        Asus vivobook s510ua bios changed to x510un
                                        by lrouw84
                                        Hi there,
                                        I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                                        I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                                        01-28-2023, 01:31 PM
                                      • Luke11037
                                        ASUS Vivobook 14 Pro M3401QA BIOS Needed
                                        by Luke11037
                                        Trying to recover the BIOS on a asus vivobook 14 M3401QA as i believe it to be corrupted however I am struggling to make a recovered bios image myself. Attached is the bios dump from the laptop.
                                        Laptop specs:
                                        CPU - Ryzen 5 5600H
                                        Model - M3401QA-KM065W
                                        SN - MBN0CX33Y50447B...
                                        05-18-2024, 06:21 AM
