Elitebook 840 g6 Touch screen not working.
  • Udemzy
    • May 2017
    • 161
    • Guatemala
    Hello, I want to know if there's a way one can make touch screen work after building bios file.
    I notice the touch function stop working both in bios setup and on windows after reprogramming the bios file, this is not the first time of experiencing.
    The model of the laptop is Elitebook 840 g6,is there a way to resolve this?
  • Udemzy
    • May 2017
    • 161
    • Guatemala
    Any help here?
      • 20949
      Was a password removed from the bios EC or a different backup flashed
      • motanya
        • Nov 2021
        • 160
        • Kenya
        Following up on this thread if there is a solution on how to get the touchscreen working
          • 20949
          There are some touch screen settings in the EC_Bios (on some models) ,if you have removed a password by editing the EC_Bios NvramActiveRegion the touchscreen setting is gone. I`m not sure if it can be edited back in afterwards. If not then use a bios + EC_Bios (or EC_Bios only) dump from a touchscreen model
          • motanya
            • Nov 2021
            • 160
            • Kenya
            Originally posted by SMDFlea
            There are some touch screen settings in the EC_Bios ,if you have removed a password by editing the EC_Bios NvramActiveRegion the touchscreen setting is gone. I`m not sure if it can be edited back in afterwards. If not then use a bios + EC_Bios (or EC_Bios only) dump from a touchscreen model
            Thank you, let me try this option
            • Gabriel Lucas
              microsoft surface pro 5 touch screen not working
              by Gabriel Lucas
              Hello everyone, I bought a Microsoft Surface Pro 5 and the touch doesn't work. According to what the previous owner said, the screen stopped working after an update. The screen has no physical damage, and the touch works for 1 second when it turns on and then stops working. I've tried updating the drivers, formatting, and returning to factory defaults, but nothing worked. Can you help me?
              02-18-2025, 09:24 AM
            • STKR123
              The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
              by STKR123
              Greetings badcaps community,
              I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
              So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
              Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
              I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
              These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
              I learned that desoldering...
              10-29-2024, 06:03 AM
            • iZakre
              HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
              by iZakre
              Hello everybody!
              To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
              The thing is that I had installed TeamViewer and could log into the computer...
              02-19-2023, 02:27 PM
            • mitchw
              HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
              by mitchw
              Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
              After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
              After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
              I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
              04-29-2025, 03:45 PM
            • zPwN!
              ENOVA NE14I310 XU133t rev 1.3 working BIOS
              by zPwN!
              Corrupted BIOS (no WIFI, graphics drivers crashing, USB port reset request failed, etc)
              Working BIOS (taken from 15.0.41.2158_CON_LP_B_PRD_EXTR_AB7F54AC but I fixed some FLEX I/O for sata ssd and GPIO VCCIO config for this model)
              System SKU NE14I310
              BIOS Version APD-BI-14-XU133TR130-TA60F-143-E ?
              Motherboard XU133T rev 1.3
              Serial Number IPNBI3X240SM2A01095
              Processor 11th Gen Intel(R) Core(TM) i3-1115G4 @ 3.00GHz 3.00 GHz
              RAM 8.00 GB
              NOTE: I'm new repairing and not sure if this is everything that needed to be configured, but the BIOS...
              01-03-2025, 01:03 AM
