BIOS request for ASUS x415dap
  • techrefurbca
    • Apr 2023
    • 25
    It is my first BIOS request here.
    I have a bios-locked AUS M415D
    ASUS X415DAP
  • qayyum786
    • Aug 2018
    • 1933
    • INDIA
    ASUS X415DAP
    ❤️YOU MUST:
    ❤️Post a BIOS BACKUP if 1 Bios or more than 1 bios file (if you have)
    ❤️Provide the full machine model number, serial number (or Service tag, SNID)
    ❤️Post under a related thread if it exists
    ❤️Motherboard part Number and revision
    • techrefurbca
      • Apr 2023
      • 25
      locked-bios dump is attached
      • qayyum786
        • Aug 2018
        • 1933
        • INDIA
        Try
        • techrefurbca
          • Apr 2023
          • 25
          Thank You, bios-lock is removed but no display (I checked on a second monitor). Also, the original bios dump had no display. So not sure if the display or lcd cable are faulty.
          Thanks so much
          • qayyum786
            • Aug 2018
            • 1933
            • INDIA
            Thanks so much
            in no display how you know that bios password is gone
            • techrefurbca
              • Apr 2023
              • 25
              It displays on a second monitor using HDMI, so probably lcd/cable faulty
              • qayyum786
                • Aug 2018
                • 1933
                • INDIA
                chk the smalest think firs
                clean lvds connector with IP and BRUSH
                chk lid chk 3v required on lvds connector pin's
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • grimacelord
                  by grimacelord
                  07-10-2025, 02:52 PM
                • throwaway327
                  by throwaway327
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  06-18-2025, 05:52 PM
                • skurvysyn
                  BIOS request - Asus Rog Zephyrus GA503RS - DANJPMB3AA0 Rev. A
                  by skurvysyn
                  laptop had dead cpu, 3x UP9030P, audio (5v+3v+MEM short) i replaced all, now laptop turns on, vcore=1.1V, vddnb=1v, vcore_gpu=0,7v, vmem=1.1, vmem_gpu=1,2v, now to not make this a diag req. - just extra info, basically:
                  original bios not available, dead bios chip, the laptop model is GA503RS, serial: N3NRCX13C597136, equipped originally with ryzen 7 6800HS, rtx 3080 - i replaced cpu, was ballsy, now there is 100-000000544 (i think its ryzen 9 6900HS/HX) - original bios behaviour=laptop turns on, cpu gpu warm, vrms continually get hotter, fan spin lower, gets faster with hotter...
                  01-08-2025, 04:45 PM
