BIOS rebuild requested for HP Pavilion Aero 13-be0003ca laptop
  • trepachka
    • Oct 2022
    • 432
    Hello, I have the following laptop:
    ProdID: 2L7M8UA#ABL
    S/N: 8CG150GPV6
    Motherboard information is below:
    HP Part# M52826-601
    448.ONE04.0011
    203016-1
    It needs BIOS repaired.
    I created a flash drive using HP firmware utility and then had it plugged into the computer. I did the standard WinLogo->B key->Power button press. A window appeared and immediately began flashing the bios using the flash drive.
    But I don't think it finished all the way. So, now when I attempt to repeat reflashing, a message comes up saying current BIOS is corrupted. It will be repaired on next boot but it never does.
    I am hoping someone can take the bin file I extracted from the bios chip and have it rebuilt. Thank you.
  • hoaca388
    Badcaps
    • Jan 2022
    • 11897
    ProdID: 2L7M8UA#ABL
    S/N: 8CG150GPV6
    Thank you.
    Backup bios file ????????????????????????????????????????????????????????
    • trepachka
      • Oct 2022
      • 432
      I am not sure why the bin file didn't get attached. Here it is.
      • hoaca388
        Badcaps
        • Jan 2022
        • 11897
        HP Pavilion Aero Laptop 13-be0003ca
        • trepachka
          • Oct 2022
          • 432
          After reflashing the bios chip with any of these files, I get the following message "The system BIOS Pending Image is being cleared. Do not shutdown or remove power from your computer during the clear. The clear will take a few minutes to complete". Then, the screen went dark.
          I let the computer sit for over an hour without any movement.
          May be I am doing this wrong. Are there 2 bios chips or just 1 bios chip? You provided 2 files which are extracted from HP website for bios recovery.
          • hoaca388
            Badcaps
            • Jan 2022
            • 11897
            There are 2 bios versions for this model, 08916 is your bios. This is original bios.
            • trepachka
              • Oct 2022
              • 432
              I tried both. I am getting the same message. Also, when attempting to flash the drive using a USB key, the message comes on and states "Backup BIOS files are either corrupted or missing"
                • 21197
                Using what sort of USB key ? .Try the HP PC Hardware Diagnostics 4-in-1 USB Key ,the 08916 bios and sig is in the 2021 softpaq .Links in post 1 -> https://www.badcaps.net/forum/troubl...flash?t=122195
                • trepachka
                  • Oct 2022
                  • 432
                  I went to HP support website and downloaded an utility program which created a bootable flash drive with the bios file on it specifically for this computer. I have done similar things many times before. On start press Windows/B Key/Power Key together. After a few seconds release the power key and keep holding the other 2 keys. I did that and the aformentioned message came up. Usually, computer immediately reads the flash drive and begins to install BIOS.
                  • the Benninger
                    • Nov 2022
                    • 189
                    • venezulan
                    I try to help, edit the bios I hope I can help you I read you in the comments
                    • trepachka
                      • Oct 2022
                      • 432
                      Hey, thanks. Computer is booting into Windows now.
                      However, every time I reboot I get a message "Manufacture Programming Mode is in Unlock Mode" followed by "Warning : OEM Keyboard Type is not set !!!"
                      Can you modify the bios file to rid the computer from these messages or is there an HP utility app that can remove these messages?
                      • trepachka
                        • Oct 2022
                        • 432
                        Never mind, I looked it up. I just used BCU utility and removed both messages. Thank you for your assistance.
                        • the Benninger
                          • Nov 2022
                          • 189
                          • venezulan
                          Ok for this we are, nice to be able to help how good you got the solution to the other everything in order
                          • Loki_Fido
                            • Mar 2025
                            • 110
                            • Japan
                            Hi
                            I hope you still have this laptop.
                            If you do, could you please send us a picture of the BIOS chip.
                            I want to see the name and the number on it.
                            • Bloodhoundje
                              HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                              by Bloodhoundje
                              I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                              I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                              After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                              I have desoldered the bios chip (GigaDevice...
                              03-16-2024, 03:12 PM
                            • Loki_Fido
                              (Weird) BIOS info for HP Pavilion Aero 13-be1021AU
                              by Loki_Fido
                              Hi folks,
                              This HP Pavilion Aero 13-be1021AU came to me for a repair. And it seems to have a weird BIOS chip. (Pic attached)
                              I asked my CH341A to read it and doesn't even know what to do with this. We are both very confused.
                              BIOS - XMC 25RU128CH10 (1.8v)
                              What the heck is this? I looked all over the MB. This is the only bios.
                              When I asked the NeoProgrammer to detect it, it just pops up an empty screen, and asked me to enter the bios number. And when I did, it doesn't do anything. NeoProgrammer showed me just this SPI ID: 204418. Don't know what...
                              03-20-2025, 01:57 AM
                            • macabook
                              by macabook
                              🧩 Initial Issue
                              07-24-2025, 02:17 PM
                            • Vesko356
                              by Vesko356
                              08-11-2023, 03:27 AM
                            • IDElectroRep
                              HP Pavilion 24-r111ne bios rebuild
                              by IDElectroRep
                              Hi
                              I need help with a corrupted bios. The pc doesn't power on with the original file. I downloaded new file from HP and the pc works but I get the "Manufacturer setup" display. I would really apreciate if someone could help with adding the missing data from the original to the new file. Thank you!
                              SN: 8CC8240QTT
                              post moved...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                              05-07-2025, 10:28 AM
