asus tp470e 8 meg bios
  • soso technician
    • Nov 2019
    • 67
    • iran
    hi...asus TP470E 8meg bios (25q64) bios need...mainboard code is tp470ez r 2.0 however it has 8 meg bios chip.as i checked other forum here all shared files were 16 meg.on the smal lable on main board was 470ez and on case the of the laptop was these information.....model TP470E SN N3N0CV10Z13411E mfd 2022-03
    attached file with this post (old.bin.) is extracted damaged bios from mainboard.please share thank you.
  • soso technician
    • Nov 2019
    • 67
    • iran
    sorry...my bad...it happend i mistake ec chip as main bios and send send ec chip data.this model have 16 meg main bios...sorry.
    • Gcs_rma
      Banned
      • Dec 2023
      • 108
      • N/A
      SN N3N0CV10Z13411E is asus TP470EZ
      bios.
      • soso technician
        • Nov 2019
        • 67
        • iran
        power led blinking...fan spin a little...it seems its restarting over and over with adapter connecting....i wonder if its because it has a dead main battery....i tested without battery.
          • 22286
          The posted bios is from Asus service, an F1 engineering bios. You have a hardware problem,not bios.
          • Gcs_rma
            Banned
            • Dec 2023
            • 108
            • N/A
            • soso technician
              • Nov 2019
              • 67
              • iran
              thank you...other technican had worked on it and he or she break down battery socket on mainboard and tried to wire main battery to motherboard !!...thats why i couldnt connect battery cause its broken....i will reject laptop to its owner.
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • pirati
                by pirati
                10-27-2025, 04:20 PM
              • grimacelord
                by grimacelord
                07-10-2025, 02:52 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • throwaway327
                by throwaway327
                Model No: RC72LA
                Serial No: SBNVKD001014459
                06-18-2025, 05:52 PM
