Asus Rog Stix G814jz - G18 Bios Help
  • igeektech
    • Jul 2017
    • 18
    Customer's device came in with black screen and will cycle every 3-4 minutes. While trying to boot keyboard and other leds light up. No external display. Please help repair Bios or locate a working. Attached is master from board.
    Thanks in advance.
    S/N - r1nrkd00429601d
    mbm - 6050a3441301 mb a02
  • qayyum786
    • Aug 2018
    • 1933
    • INDIA
    Thanks in advance.
    Look @ another 256 number chip
    • igeektech
      • Jul 2017
      • 18
      Hows this file?
      • qayyum786
        • Aug 2018
        • 1933
        • INDIA
        Hows this file?
        its just 2 mb your file should be 32mb
        • igeektech
          • Jul 2017
          • 18
          Last one
          • igeektech
            • Jul 2017
            • 18
            It's 32mb unzipped
            • qayyum786
              • Aug 2018
              • 1933
              • INDIA
              Last one
              Try
              • igeektech
                • Jul 2017
                • 18
                Try
                HIGH FIVE!
                Worked like a charm, still need to go and check everything but thanks so much! qayyum786
                • Vincent Kahle
                  • Jun 2025
                  • 4
                  Can i use this? My laptop have a black screen and i dont know what i can do. I can write a bios on the chip but it shows me its to big
                  • Vincent Kahle
                    • Jun 2025
                    • 4
                    I have a winbond 25q16jwniq asus rog strix scar 18 g814jz but the laptop dont work anymore i flach something wrong
                    • peste
                      • Dec 2016
                      • 12254
                      • ROMANIA
                      post S/N, full name and model, motherboard model, etc.
                      post the contents of the bios chip even if it is corrupted..
                      • razor_amd
                        by razor_amd
                        12-15-2020, 07:07 PM
                      • throwaway327
                        by throwaway327
                        Model No: RC72LA
                        Serial No: SBNVKD001014459
                        06-18-2025, 05:52 PM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • lrouw84
                        by lrouw84
                        Hi there,
                        01-28-2023, 01:31 PM
                      • DynaxSC
                        by DynaxSC
                        06-14-2024, 03:49 PM
