Lenovo Thinkpad Ec Pwd Bypass
  • zomi
    • Nov 2011
    • 513
    #141
    Yes you are correct..
    sorry my mistake.
    • munir100
      • Dec 2018
      • 188
      • uae
      #142
      hi lenovo t490s ft 491 fx 390 nm-b891 rev 2.0 MEC1663-bao which point you short circuit to reset the password
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1358
        • France
        #143
        https://www.badcaps.net/forum/troubl...03#post3239703
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1358
          • France
          #144
          Originally posted by Gernet
          I think the problem is which interface is used LPC or ESPI.
          I have installed resistor R1310 =Disable eSPI= on my NM-D491.
          But no initialization - nо image and Fan on max.
          I tried several things too, but without results
          • spacez
            • Nov 2023
            • 69
            • FR
            #145
            about T14 gen 3 AMD NM-E441 rev1.0..locked with svp password ... I managed to remove this SVP password with test point in ESPI-IO3 and gnd . but instead of entering bios he asks for another password but not the SVP one . by clicking only on enter it can go into the bios. but password change is not accessible..
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1358
              • France
              #146
              Lpc bus is still used on this model?
              • salawayon
                • Nov 2012
                • 578
                • philippines
                #147
                got X1 CARBON 7TH GEN_NM-C661_MEC1663,
                changed Supervisor Password (Blank), Changed System Management Password (Blank), Power ON Password (Blank) and Clear Security Chip, then Press CTRL ALT DEL to restart, but the Password still Present. did i make a mistake on this model?
                Clear supervisor password with twice blank
                and manager with twice blank password
                Clear security chip too
                After just Ctrl alt del and try
                if Mec need many tries
                • urani
                  TechPro
                  • Mar 2017
                  • 10
                  Any solution for the Lenovo T14s
                  NM-D362 Rev: 4.0
                  MEC1503-EA2
                  • spacez
                    • Nov 2023
                    • 69
                    • FR
                    #149
                    hello ..IF somebody can locate ESPI_IO3 for NM-D341 X1 Carbon 9th Gen . TO test somethinq. thanks in advance
                    • Gernet
                      • May 2021
                      • 60
                      • Italy
                      #150
                      Use shematics and boardview https://www.badcaps.net/forum/troubl...tic#post102868
                      • salawayon
                        • Nov 2012
                        • 578
                        • philippines
                        #151
                        Originally posted by black0hackers
                        Hi, i try on X1 carbon G7
                        NM-C661
                        I short pin LPC_AD0 to GND but not done
                        do i wrong pin?
                        Have you sorted out the problem? Got same unit and able to access the bios setup thru PIN 10 to GND trick but I can't disable the Supervisor Password after following the given instructions posted here.
                        • spacez
                          • Nov 2023
                          • 69
                          • FR
                          #152
                          THANKS a lot for sharing test point .. unfortunatly didnt work.. .. i need the one who is close to MEC1503H....i have aleready boardview but not clair .
                          • feherhollo
                            • Nov 2019
                            • 110
                            • Hungary
                            #153
                            For Lenovo T490s NM-B891 Which pin to short to GND?
                            I have checked all posts and found the schematics just need confirmation as I'm right.
                            I need to ground PIN 10 of the J9301?? (I will use tweezers...)
                            Thanks for the answer
                            • danito
                              • Jun 2016
                              • 1259
                              #154
                              Maxpower3 can you help me please for a t14 gen 3 NM-E981 with NCPX997 what should be done?
                              • anhbanxoi
                                • Sep 2021
                                • 180
                                • VN
                                #155
                                Did you try ESPI_RESET pin?
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1358
                                  • France
                                  #156
                                  try
                                  T14 gen 3 AMD NM-E441 with NPCX997
                                  try this morning ,not worked
                                  • Maxpower3
                                    Bad Veteran
                                    • Feb 2018
                                    • 1358
                                    • France
                                    #157
                                    edit
                                    after many try
                                    I managed to enter the bios, but the tabs are missing.
ID:	3279733 Click image for larger version
                                    The Espi connector is not connected, the resistors are missing
                                    so it must be connected near the EC
                                    I have to start very early to pass, well before backlighting.
                                    I have not yet fully understood how.
                                    I also managed to get errors like uuid or others
                                    not yet able to remove the password
                                    • volinakis
                                      • Jan 2021
                                      • 2876
                                      • N/A
                                      #158
                                      Maxpower3
                                      I confirm your genius method is working for T14 gen 1 AMD GT4A1 NM-C801 rev.1.0 Thank you very much!
                                      • zomi
                                        • Nov 2011
                                        • 513
                                        #159
                                        Are you doing soon as you switch on...
                                        time for stop watch and playing with it maybe
                                        maybe due to fatser bus it mroe critcal the timing who knows.
                                        • Maxpower3
                                          Bad Veteran
                                          • Feb 2018
                                          • 1358
                                          • France
                                          #160
                                          I have to boot a few seconds after a ctrl alt del.
                                          just before the light
                                          no cmos, no power button, only one card. so not much choice
                                          the timings already change between Mec ite and ncp.
                                          I have a slow startup on this machine, it's not easy to know when to play
                                          this AMD model had to keep the LPC because it does not freeze easily​
                                            Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 11:40 AM
