Lenovo Thinkpad Ec Pwd Bypass
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1358
    • France
    T14 Gen2 Amd NM-D451 IT5679VG
    Tested ok
Name:	T14 Gen2 Amd NM-D451 IT5679VG.jpg
    • kitor
      • Apr 2019
      • 47
      • Poland
      As written in another thread, L14 G2 AMD, NM-D391 + NPCE68B works fine
      • miansh621
        Banned
        • May 2022
        • 133
        • pakistan
        • khaledmosa99
          • Dec 2014
          • 75
          • egypt
          pleas give me an advice for thinkpad p53
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1358
            • France
            T480 NM-B501
            tested ok
            • mazoot
              iFixit
              • Jan 2019
              • 41
              • Moldova
              #26
              on IT8227E 256EC dump the password area between 0x3EF00--0x3EF40
              Kill the state in yourself and you will be free like a wind...
              • ibo
                • Oct 2019
                • 108
                • Turkiye
                #27
                HI
                I have a Thinkpad T15 Gen2 with mec1503. i can try to unlock if the pin is known to short.
                NM-D352 Board
                  Vesko356 commented
                  Editing a comment
                  Read post #1:
                  Originally posted by Maxpower3
                  ...but my tests failed with the Mec1503
                  The LPC bus is no longer used, it has been replaced by eSPI
              • imranromi
                • Jan 2015
                • 1290
                • Pakistan
                #28
                Send board code will share you point i believe can unlock P53.
                • khaledmosa99
                  • Dec 2014
                  • 75
                  • egypt
                  #29
                  nm-c262 thank you sair
                  • danito
                    • Jun 2016
                    • 1259
                    #30
                    Try
                    • aamisterdownload
                      • Mar 2024
                      • Belgium
                      #31
                      Where can I buy a cable with one end USB type B and the other end a pen/stift?
                      For shorting are you holding the pin on GND already when starting up the laptop and then releasing it at a certain moment while keep pressing F1. It is not clear to me when exactly releasing the pen?
                      I suppose it doesn't matter to use GND1 or GND2?
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1358
                        • France
                        #32
                        Do it yourself
                        wait 1-2 seconds after turning on or wait for the backlight.
                        make the contact, wait 1or2 sec, release.and,press f1
                        Sometimes you may get a fan error which turns off the PC, sometimes you can bypass it by pressing Esc.
                        other error may occur bad data /uuid /serial etc..this is good sign
                        just the timming doesn't is not good
                        The method depends on the Ec (timings are different)​, it takes several attempts before you succeed and understand.
                        • noregret70
                          • Jan 2020
                          • 11
                          • Russia
                          #33
                          Great Job man . But MEc1633 its realy pain , i catch it on 14 try ... at least not brick MB.
                          • Maxpower3
                            Bad Veteran
                            • Feb 2018
                            • 1358
                            • France
                            #34
                            for Mec, you have to start early, they are harder
                            • danito
                              • Jun 2016
                              • 1259
                              #35
                              yes, very hard to catch him
                              • aamisterdownload
                                • Mar 2024
                                • Belgium
                                #36
                                For making the cable yourself. I do not known what to do.
                                Can I take for example the following piece and just take the red cable of it and connect the red wire (+5V) to a probe? And cutting off the 3 other cables?
                                Links:
                                https://shorturl.at/vAFI9
                                For connecting the red cable to a probe do something like in the following video?
                                How to make the best DIY back probes in 2 minutes.
                                  • 22275
                                  Links:
                                  Thats overkill, you can just use a piece of wire or even tweazers
                                  • Patrik Vilja
                                    • Apr 2024
                                    • 7
                                    • Sverige
                                    #38
                                    When looking at Espi and lpc, the big difference Was the voltage.. 3.3 for lpc and 1.8 for espi..
                                    So feeding 5v might be the only issue regarding mec1500 and 1700(i have 1722..)
                                    So, update tomorrow with 1.8v feed..
                                    Sleep now..
                                    • Patrik Vilja
                                      • Apr 2024
                                      • 7
                                      • Sverige
                                      #39
                                      Could someone help point out lenovo thinkpad x1 yoga gen7?
                                      • Patrik Vilja
                                        • Apr 2024
                                        • 7
                                        • Sverige
                                        #40
                                          Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 11:40 AM
