Lenovo Thinkpad Ec Pwd Bypass
  • zomi
    • Nov 2011
    • 513
    #121
    I uploaded the schematic and boardview for p15/p17 g2
    in the schematics forum,
    https://www.badcaps.net/forum/troubl...ptor-blackbird
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1358
      • France
      #122
      P15 P17 Gen2 NM-D491 NPCX997KA0BX
      I have one to do, I will try soon
      To try
      • Arenz
        • May 2024
        • 8
        • France
        #123
        Originally posted by Maxpower3
        try
        Unfortunately, it didn't work. I tried both but no success.
        I don't know if my "ground" is really good so let me know if I need to change it.
        I think the issue is probably the timing because sometimes (2 times on the +50 I did) I got error message (two times different) but the other tries were just normal.
        In the video, you have a lenovo startup screen and then you do the magic trick, but me, I don't have the first lenovo "Entering setup" image so I can't refer to that.
        I don't know if you have any tips or something else but I'll gladly take it.
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1358
          • France
          #124
          if you have mistakes, it's a good sign. you have to keep trying.
          check your pencil, it may be cut in the wire.
          maybe
          https://www.badcaps.net/forum/troubl...32#post3257932
          or try test connector JESPI1 with pin 2/3/4 or 5 with pin 6 Gnd
          https://www.badcaps.net/forum/troubl...82#post3274982
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1358
            • France
            #125
            Is your screen taking too long to display with l'hdmi? Use the original screen on the bench.
            • Arenz
              • May 2024
              • 8
              • France
              #126
              I think that may be the case honestly. I'll try to do that but the setup is a bit complicated right now lol.
              And I'll try tomorrow with the espi 1 too
              • zomi
                • Nov 2011
                • 513
                #127
                any ideas where best to do the x1 titanium
                https://www.badcaps.net/forum/troubl...od-lhr-1-19764
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1358
                  • France
                  #128
                  Mec1503 not work
                  you can try, but I don't believe it​​
                  • Gernet
                    • May 2021
                    • 60
                    • Italy
                    #129
                    Maxpower3​, I have ThinkPad P15 Gen 2 with SVP
                    I shorten any pin ESPI_IO0..3 , but after it freez
                    • CraterM
                      • Mar 2018
                      • 180
                      • Moldova
                      #130
                      X997 not work
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1358
                        • France
                        #131
                        Originally posted by CraterM
                        X997 not work
                        I tried this morning, didn't work, freeze on P15 NM-C651 NCPX897​
                        • Gernet
                          • May 2021
                          • 60
                          • Italy
                          #132
                          I think the problem is which interface is used LPC or ESPI.
                          NM-C262 (NPCX897) use LPC - work https://www.badcaps.net/forum/troubl...46#post3274946
                          NM-C651(NPCX897) use ESPI - dont work , freez https://www.badcaps.net/forum/troubl...69#post3276369
                          • Maxpower3
                            Bad Veteran
                            • Feb 2018
                            • 1358
                            • France
                            #133
                            I tested with 1.8v instead of gnd, but continues as normal. no error or freeze
                            • Gernet
                              • May 2021
                              • 60
                              • Italy
                              #134
                              I don't understand. What board? Where is need =1.8v instead of gnd=
                              I work with NM-D491 - NPCX997 - ESPI
                              • zomi
                                • Nov 2011
                                • 513
                                #135
                                I believe he is testing injecting 1.8v on
                                at the espi point.
                                • zomi
                                  • Nov 2011
                                  • 513
                                  #136
                                  what would happen if we disable the espi ?
                                  • Maxpower3
                                    Bad Veteran
                                    • Feb 2018
                                    • 1358
                                    • France
                                    #137
                                    P15 NM-C651 NCPX897
                                    exact
                                    here?
                                    • Gernet
                                      • May 2021
                                      • 60
                                      • Italy
                                      #138
                                      I haven't tried. Do you think, I should try Disable ESPI. In my NM-D491 , I must add resistor R1310. This is right?
                                      • Gernet
                                        • May 2021
                                        • 60
                                        • Italy
                                        #139
                                        I have installed resistor R1310 =Disable eSPI= on my NM-D491.
                                        But no initialization - nо image and Fan on max.
                                        Next
                                        I remove R1310 - there is initialization and image.
                                        Maybe on NM-D491 not possible use LPC.
                                        • Gernet
                                          • May 2021
                                          • 60
                                          • Italy
                                          #140
                                          PCH Tiger Lake dont have LPC? 🤔​
                                            Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 11:40 AM
