Problem bios asus x509jb
  • LoudaAbdelghani
    • Mar 2024
    • 4
    hello all customer had a problem in laptop
    asus x509jb i7 10th generation the problem of this laptop is i want to reset bios from cmos but i cant found it also when i turn my laptop on just black screen i tried to enter in bios but there is nothing just black screen
  • LoudaAbdelghani
    • Mar 2024
    • 4
      • 22289
      Type and post the serial number.Post your bios backup
      You MUST:
      • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • cr4zychriss
        by cr4zychriss
        • Rebrand: PC Specialist
        11-14-2025, 04:04 PM
      • lucaszmn
        by lucaszmn
        Problem:
        Initial Findings:
        • I concluded that the
        08-12-2025, 03:01 PM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
