Problem bios asus x509jb
  • LoudaAbdelghani
    • Mar 2024
    • 4
    hello all customer had a problem in laptop
    asus x509jb i7 10th generation the problem of this laptop is i want to reset bios from cmos but i cant found it also when i turn my laptop on just black screen i tried to enter in bios but there is nothing just black screen
  • LoudaAbdelghani
    • Mar 2024
    • 4
      • 20773
      Type and post the serial number.Post your bios backup
      You MUST:
      • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • futadmytro
        Asus g713qm-es94 stuck on boot bios problem
        by futadmytro
        sn^M4NRKD02753616E
        MB- g533-6050a3250201-MB-A03
        Stuck on boot after ROG logo, did not enter to bios
        In flash bios , laprop boot but have video issue
        orig bios...
        06-25-2025, 08:07 AM
      • pkslowk
        Debug Card Error Code and Solution
        by pkslowk
        Sr. Motherboard Debug Error Code Solution
        1 Intel 845 E9 Bios Related Problem
        2 Intel 845 D4 CPU Socket Related problem
        3 Intel 845 37 Bios Related Problem
        4 Intel 845 7C Bios Related Problem
        5 Intel 945GCPE 34 Bios Related Problem
        6 Gigabyte 845 2 Ram Related Problem
        7 IBM Server A6 A7 Ram Mismatch Problem
        8 Asus 845 29 CPU Related Problem
        9 Lenovo I946 97 C-Mos Jumper related
        10 Gigabyte 845 A0 CPU Related Problem
        11 Asrock G31M-VS D7 Bios Related Problem
        12 Compaq 845 BD-70G B0 CPU Socket Related problem...
        01-28-2021, 12:51 PM
