Hello, I share this functional bios of the XU133S REV 5.0 to share that it is not available anywhere.
XU133S REV 5.0 BIOS WORK
by ngngocson113hi everyone
i need bios asus tp301uj ( "uma " vga share)
my mainboard doesn't use vga chip and it uses vga together with cpu.
I used some bios files (good).of the mainboard that uses vga chip. but can not turn on power.Meanwhile,its original bios file can turn on power But nothing on the screen
thanks everyone....-
Channel: BIOS Requests ONLY!
by NeddsmeHie.
I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
I managed to run Windows troubleshooting and...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
I'm not a super pro like some here, when it comes to firmware. I have a machine with the following specs:
ENVY X360
15-ew0013dx
SN: CND2261KS3
Prod: 698V0UA
Board: LA-M021P Rev 1A
Chip# Winbond 25R128JVSN
Basically, when I power it up, I get no video, and the fans run hard - nothing else. Seems like a BIOS issue to me, so I posted a request in the BIOS request section. I haven't heard anything back(and that's fine) So I tried downloading the BIOS from HP, then I extracted it and flashed it onto the chip. Unfortunately, all I get is the power...10-09-2024, 08:40 AM - Loading...
