Asus R510J - MB X550JX black screen
  • bouny56
    • Jan 2023
    • 68
    • france
    Hello
    I have a Asus R510J start but stay on black screen
    Everything look ok on the motherboard
    Maybe Bios ?
    Mb : X550JX Rev 2.1
    Serial : G1N0CV210689045
    on asus support bios : X550JXAS210
    try some bios but not find the good one
    Can you help me please?
    Thx
  • volinakis
    • Jan 2021
    • 2876
    • N/A
    Originally posted by bouny56
    Hello
    Maybe Bios ?
    Mb : X550JX Rev 2.1
    Thx
    try
    • bouny56
      • Jan 2023
      • 68
      • france
      Originally posted by volinakis
      try
      Hello and thanks
      Same problem, the motherboard start , 1.2 amp , fan turn , but no picture
      Try another screen same
      Maybe the onboard ram ?
      • qayyum786
        • Aug 2018
        • 1959
        • INDIA
        Hello and thanks
        On board ram disabled in bios try with external ram in ram slot
        • Technodoc
          ASUS G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
          by Technodoc
          Asus laptop G614JZ-N3012W Rog Strix with i7
          Mainboard G634J-PMV-VGT
          6050A3441302-MB-A01
          2023-02-10
          Power button works okay....power light goes on
          Red "bottom" leds go on
          Charging led works
          Fans do not spin, capslock key does nothing, screen stays black
          I would like to program the bios again, to rule out a corrupted bios.
          However I run into a size error
          The bios chip is a Winbond 25R256JVEN
          Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
          02-24-2025, 04:46 AM
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • grimacelord
          by grimacelord
          07-10-2025, 02:52 PM
        • mitchw
          HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
          by mitchw
          Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
          After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
          After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
          I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
          04-29-2025, 03:45 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
