lenovo js476& js576 nm-e331 bios
Every donation made will go towards server fees and maintenance costs. -
Hi there,
lenovo v15 g3 iap
sr PF4BK78A
the backup file doesn't work and doesn't restore and now it doesn't power up anymore
it have 2 bios chip
need bios binComment
post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
Don't post pictures unless asked...
read the forum rules..
Every donation made will go towards server fees and maintenance costs.Comment
i've flashed main and ec but no lucky: the power light keeps blinking 12 times and after turn off it restart every time in an infinite loop.
Also if i reconnect internal battery, the power light go on and after a while it turn off
the last screen before the problem was a lenovo screen with this messages: Warning: Please do not power off while BIOS self recovery processing and when it reached 100% it turned off and never turned on again.
Bios was upgraded by Windows 11 Update.Comment
P.S. I didn't wrote the second file that you have here which is 256 KB in size as my second BIOS chip is 8MB in size after reading backup..,,Attached FilesComment
Best regardsComment
https://github.com/liho98/lenovo-bio...traction-guide
Can you help us out or tell how to do extraction of this new file here at this link?
https://pcsupport.lenovo.com/us/zh/p...eapad-1-15iau7
It seems that on the original file from Lenovo (JKCN50WW) which is around 26 MB in size, are packaged both BIOS-es the one 8 MB in size and the 16MB in sizeComment
As I wrote this 16MB file and it did not work, now I notice that there is a fresh new BIOS uploaded on Lenovo site, but I am unable to extract both the firmwares.bin from that file using this tutorial here:
hi j nedd bios dla lenovo ideapad 1 15IAU7 S.N PF4D1TAV JS576Badcaps Electronics Repair Forum & Schematic SearchComment
Wrote the first file 16MB in size after I made a backup first which is also 16MB in size, and now it behaves a little differently, but still no power ON laptop. I read also the second chip near it which is 8MB in size and uploaded here if you can help me, thanks so much
My laptop infos are :
Serial PF4A83NG
Model Name V15 G3 IAP
MTM: 82TT00A5RM
MO: PF9XB3512123
Hello, first time posting here
Lenovo Ideapad 1 15IAU7
No image, caps lock and esc key leds on, power led flashing
Hope you can help me
Thank youAttached FilesComment
read the forum rules..https://www.badcaps.net/forum/troubl...before-postingComment
Type the laptop serial number, full name and model, motherboard model, etc.
SN: PF53V5RQ
Ideapad 1 15IAU7
MB: JS476&JS576 NM-E331 REV 1.0Comment
you have everything you need at post #4...
https://www.badcaps.net/forum/troubl...os#post3215835
The second file isn't available for downloadComment
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
Channel: BIOS Requests ONLY!
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM -
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM -
by TecnicaNTTHi all,
I got a Lenovo Thinkbook 16P G2 ACH on the bench with a botched BIOS (somehow my client blanked it). I restored the laptop and got it up and running with original BIOS from Lenovo Support website.
My problem is now that the machine details are missing in the BIOS (Serial Number, MTM, etc.)
I tried to write the details with the Lenovo Uone Tool but had now luck. It is giving me an error: "ERROR: Locate protocol with LenovoEeprom, Status=[e]. EEPROM fail when reading or writing data."
I am now asking here for help if anyone knows how to do this in...-
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
- Loading...
