5300 2 in 1 (18828-1) boot delay, tpm error
  • r ez a
    • Sep 2014
    • 39
    • iran
    hello my friends
    i have a laptop here that came for this error
    "Alert! TPM device is not detected"
    and daley in boot
    i flashed bios with different files,aslo clean ME files
    but delay was still there
    is there any other reason for 15 sec delay in boot?
    than​
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules.
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    Become a Badcaps supporter
    Thanks to all supporters.
    • r ez a
      • Sep 2014
      • 39
      • iran
      sorry
      full model is Latitude 5300 2-in-1
      platform is Northbay TBT, 18828-1
      service tag :H05PMW2
      this is dump file and clean ME file
      • qayyum786
        • Aug 2018
        • 1959
        • INDIA
        Here is your new bios
        • r ez a
          • Sep 2014
          • 39
          • iran
          thanks but 15s delay is still there
          • dennis akumu
            • Mar 2018
            • 113
            • kenya
            DELL Latitude 5300
            Board no : NORTHBAY TBT MB FG 18828-1
            service tag : 9X85QT2
            attached is the original backup
            please clean me
            • lapfix
              • Mar 2020
              • 2764
              • my workshop
              Originally posted by dennis akumu
              DELL Latitude 5300
              please clean me
              This is your clean me
              Bios Version : 1.31.0
              Me Version : 12.0.94.2380 VPro LP
              • Hungdunglaptop
                Latitude 5300 error TPM not detected
                by Hungdunglaptop
                i have Dell 5300 run normanly , but after update bios have error TPM not Detected
                Help me Fix error
                Thankyou so much
                Model Latitude 5300
                ST: JY8KJW2
                Mainboard: 18827-1...
                12-26-2024, 11:09 PM
              • Sus256
                HISENSE 65E7KQ PRO - no boot
                by Sus256
                Hi all!
                HISENSE 65E7KQ PRO
                RSAG7.820.13512 - chassis
                MT9618BAATAB - cpu
                RSAG7.820.12059 - power
                HD650Y3U77 - panel
                KLM8G1GETF - emmc
                Replaced emmc.
                Terminal log
                UART
                AC_ON
                E-B
                FDE enabled
                06-01-2025, 02:11 AM
              • SiO2
                GTX 1070: No output, VRAM? Issues with mats
                by SiO2
                I have an Inno3D Herculez X3 GTX 1070, which does not show any image. After ~30s, the monitor turns on and displays a black screen.
                The card however is detected by the OS, GPU-Z shows 0 MB VRAM. The driver crashed during boot.
                Visually the card is in very good condition. No visible signs of defects, all voltages are present and within reasonable range, but on the high side I think: Vcore = 0.9 V, Vmem = 1.5 V. Vcore measures ~250 mOhm according to my DMM.
                This leads me to the assumption, that something VRAM-related is off. So the natural first step...
                04-23-2022, 05:44 AM
              • sushilachuthan
                APC UPS error P13
                by sushilachuthan
                one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
                the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
                The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
                We replaced the SCR with new device,, but the device is not power on as expected.
                Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
                09-26-2025, 09:00 AM
              • dragometin
                Hitachi 40HYC42
                by dragometin
                TV Model: Hitachi 40HYC42
                Power Supply: 17IPS71
                MainBoard: 17MB95M
                Panel: VES400UNDS-2D-NO3
                When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                Is there any variants on 17IPS71 power supply's?
                UART output pins 10 and 12 on scart connector:
                Code:
                12:24:04.595
                08-08-2024, 05:53 AM
