Bios ASUS X441UR
  • Jezt
    • Oct 2023
    • 13
    • Philippines
    Bios ASUS X441UR
    Hello, Pls give me working bios for this model (Please see the board code)
    P/N X441UR-GA046T
    S/N H6N0CV03073623E
    Tnx in advance..
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    P/N X441UR-GA046T
    S/N H6N0CV03073623E
    Tnx in advance..
    You MUST:
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    Become a Badcaps supporter
    Thanks to all supporters.​
    • Jezt
      • Oct 2023
      • 13
      • Philippines
      You MUST:
      Im so sorry. i added the fault as reply. thanks for the reminder.
      No display after failed update. I've search and tried firmwares same board number. Problem is it takes too long to boot up, i assumed there is specific variation.
      • leo037_2023
        DEMIGOD OF BIOS
        • Oct 2023
        • 63
        • Buenos Aires - Argentina
        P/N X441UR-GA046T
        S/N H6N0CV03073623E
        Tnx in advance..
        TRY with this version i cleaned for you. TRY and tell how you went. PLEASE
        • Jezt
          • Oct 2023
          • 13
          • Philippines
          No luck.. activity led lights when the charger is plugged but the charging indicator is off. No dispaly, fan don spin up. :-(
          • Jezt
            • Oct 2023
            • 13
            • Philippines
            I think the bios dump i uploaded is just messed up..
            • leo037_2023
              DEMIGOD OF BIOS
              • Oct 2023
              • 63
              P/N X441UR-GA046T
              S/N H6N0CV03073623E
              Tnx in advance..
              TRY with this bios i download from the ASUS PAGE and armed and edited. try with this..... and tell me if work
              • Vesko356
                Vesko356 commented
                Editing a comment
                Stop using this crap called "Intel ME region injector" to clean the ME Firmware!
                Besides first try to replace the Bios region only with the one downloaded from Asus, in most of the cases this is enough to repair the bricked bios, if not - then clean the ME Firmware using proper version of Flash Image Tool afterwards.
            • leo037_2023
              DEMIGOD OF BIOS
              • Oct 2023
              • 63
              i dont use intel me injector and just find the region me in the repository and use HxD . end...
              • Vesko356
                Vesko356 commented
                Editing a comment
                Come again?? You can't use HxD or ME injector to do that! ME Firmware can be cleaned with corresponding version of FIT ONLY!
            • Jezt
              • Oct 2023
              • 13
              • Philippines
              Still havent had any luck pls help any one.​​​​​​​​​​​​
              • minhdigital
                • Nov 2022
                • 762
                • Vietnam
                Send to you
                • Jezt
                  • Oct 2023
                  • 13
                  • Philippines
                  Originally posted by minhdigital
                  Send to you
                  tried it man, the battery charging indicator lights up when i turn on the device.. still no display or any acitivity exept that
                  • peste
                    • Dec 2016
                    • 13258
                    • ROMANIA
                    TRY..
                    • Jezt
                      • Oct 2023
                      • 13
                      • Philippines
                      Send to you
                      This one works laptop boot up normal exept the charger has to be plugged and the charging indicator blinks white
                      • Jezt
                        • Oct 2023
                        • 13
                        • Philippines
                        Send to you
                        Boss, pls fix this bios again..🙏
                        • minhdigital
                          • Nov 2022
                          • 762
                          • Vietnam
                          Check Screw there
                          • Jezt
                            • Oct 2023
                            • 13
                            • Philippines
                            Thanks man.. I didnt see that
                            • throwaway327
                              by throwaway327
                              Model No: RC72LA
                              Serial No: SBNVKD001014459
                              06-18-2025, 05:52 PM
                            • razor_amd
                              by razor_amd
                              12-15-2020, 07:07 PM
                            • 0xx
                              2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                              by 0xx
                              Hi folks,
                              My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                              What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                              I assumed that Windows Update was interrupted due to closing...
                              09-14-2025, 03:46 PM
                            • futadmytro
                              Asus g713qm-es94 stuck on boot bios problem
                              by futadmytro
                              sn^M4NRKD02753616E
                              MB- g533-6050a3250201-MB-A03
                              Stuck on boot after ROG logo, did not enter to bios
                              In flash bios , laprop boot but have video issue
                              orig bios...
                              06-25-2025, 08:07 AM
                            • keropi
                              Lenovo M92p TINY 3238 lost ability to boot after BIOS update
                              by keropi
                              Hello!
                              yesterday I received from eBay a Lenovo M92p TINY model 3238 system with 4GB of RAM and a 500GB mechanical HDD.
                              I tested it and it worked fine, it booted to a fresh Win10 x64 French OS .
                              The plan was to replace the mechanical HDD with an SDD one and upgrade RAM to the max 16GB since I had 2x 8GB SODIMM modules.
                              I noticed that there was an update on the Lenovo support site so I thought I'd do that first and then proceed with the upgrades and installation of new OS.
                              The windows BIOS update completed successfully and the system booted to a bios-like...
                              12-17-2021, 09:36 AM
