Need to copy DMI info for HP ProBook 650 G2 Bios
  • Caimano
    • Nov 2020
    • 54
    • Italia
    UPDATE of JANUARY 5th : I am cancelling this post because problem has been solved by creating a new bios starting from the old one with correct dmi and cleaning ME. everything works fine . thanks anyway
    Hi, I am replacing a motherboard circus-6050A2723701-MB-A02 to an HP 650 G2 laptop because the original one was faulty. I bought and repaired a used MB which works fine now with its BIOS, but I wanted to copy the DMI data from the old to the new MB. I created with Flash Image Tool a new bios starting from the old original chip , cleaned ME region and new updated dump region extracted from HP site, but I probably did something wrong and it does not work on the new motherboard. So I decided to keep the BIOS of the new board and just copy over the DMI data from the old one, but I am unsure what's the offset of the data to copy because it's different on the two dumps. Could anyone help me out?
    Here are the dumps and the infos
    Could you please help me to copy DMI data from old Bios to new one?
    Is it better to clean ME also?
    Thanks in advance
  • OskarB98
    • Aug 2018
    • 75
    • Sverige
    Hello!
    I have a 650 G2 that originally wasnt booting due to corrupt BIOS.
    I flashed it using a BIOS i downloaded from HP website, but this .bin does not have serial number/clean ME?/other information. And it also says it's in manufavturer programming mode when booting.
    Could someone please help me transfering this data from my corrupt BIOS-file?
    I will attach original file, and the file that currently works to boot machine into BIOS.
    • Vesko356
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      Originally posted by OskarB98
      Hello!
      Thread merged.
      You MUST:
      Become a Badcaps supporter
      Thanks to all supporters.
      • OskarB98
        • Aug 2018
        • 75
        • Sverige
        Sorry!
        Model: HP ProBook 650 G2
        Serial number: 5CG7082XN9
        Product number: X2F75EA#AK8
        Board number: CIRCUS-6050A2723701 (i5-6300U)
        • hoaca388
          Badcaps
          • Jan 2022
          • 11729
          Sorry!
          sss
          • ajohmobile
            • Jan 2024
            • Cameroon
            Greeting i have a similar problem .. an hp laptop was brought to me by my junior man and i discovered that the bios has been clean. Please how or where can i locate the the board number so that i can look for the right bios dump to write on it..
            Serial number: 5CG6320Q61
            Product number: L8U48AV​
            • leone8238
              • 9
              • Slovenija
              Hi, I have a HP ProBook 650 G2 that had a corrupt bios installed (not original) and wouldn't boot (fan spinning very fast and black screen). I found a .bin dump online for the same model (attached) and after flashing it the laptop booted up but has different serial numbers and "Machine not in commited state" error.
              I tried to change the serial numbers with BiosConfigUtility64 and Wndmifit64 but failed because MPM is locked. My goal here is to unlock MPM, change the serial numbers to original and get rid of the "Machine not in commited state" error. Any help would be greatly appreciated.​
              Here is my original laptop info:
              Motherboard: CIRCUS-6050A2723701-MB-A02
              Product Name : HP ProBook 650 G2
              Serial Number : 5CG6221HSH
              Product Number : V1C17EA#BED
              BuildID = 15WWCICW601#SBED#DBED
              FEATUREBYTE = 3X47676J6S6Z6b7H7M7Q7W7saBaEapaqawbhdQdUeh.QD
            • Mr.Nobody
              Retired
              • Apr 2022
              • 73
              Did you use BCU from HP ?
              If not, you find it in a link from this post : https://www.badcaps.net/forum/troubl...66#post1816066
              If yes, upload the config.txt
              • leone8238
                • 9
                • Slovenija
                Yes, i have used BCU and got "Access denied, returnCode = 6" error when trying to change serial and other numbers. Here is current config in the attachment
                • qayyum786
                  • Aug 2018
                  • 1933
                  • INDIA
                  post your originale bios even its corrupted
                  • Mr.Nobody
                    Retired
                    • Apr 2022
                    • 73
                    Your config.txt is OK...maybe qayyum786 can rebuild your original corrupted BIOS...
                    Until then try to write this config:
                    • leone8238
                      • 9
                      • Slovenija
                      I have tried the attached config, but got same error as before. Probably because MPM is still locked.
                      Unfortunately I no longer have the original (corrupt) bios, but i did a quick look at it with UEFITool in hex view and the DMI was all different so it was definitely not original from this laptop.
                      • Mr.Nobody
                        Retired
                        • Apr 2022
                        • 73
                        Try then this bios and write DMI
                        • leone8238
                          • 9
                          • Slovenija
                          I have flashed the bios in attachment and everything went just fine, already entered all DMI info. Now i only have to solve the "Machine is not in commited state!" warning.
                          I have read something about AMT function, but i am not sure if my laptop has it or not.
                          • Mr.Nobody
                            Retired
                            • Apr 2022
                            • 73
                            The way to determine whether a certain model supports the AMT function is to check the Intel CPU sticker on the palm rest...if it has...
                            If it has the word vPro, it means that the AMT function is supported and the AMT function must be enabled when defining; otherwise, it means that the AMT function is not supported and must be disabled when defining.
                            On Lenovo by example, the vPro versions have 2 BIOS chips...I don't know about HP...
                            Try with this tool:
                            • leone8238
                              • 9
                              • Slovenija
                              Try with this tool:
                              I found that my laptop does not have vPro by sticker and it having intel i5 6200U.
                              I have tried Brand11, 12, 13 and AMTool DOS and got these results in the attachment. There seems to be some kind of ME error
                              • Mr.Nobody
                                Retired
                                • Apr 2022
                                • 73
                                I don't think so...the ME Region from the dump it's a factory one, brand new...
                                More than an incompatibility for some hw components...because it's not a bios for this machine...
                                I have another images try...enter your DMI info...
                                • leone8238
                                  • 9
                                  • Slovenija
                                  I have used the v3 bios and entered all DMI info. I no longer have the "Machine not in commited state" error.
                                  When updating bios from 1.60 to 1.61 i got this warning. Should i use HP_tools to set AMT?
                                  • Mr.Nobody
                                    Retired
                                    • Apr 2022
                                    • 73
                                    That's exactly your problem
                                    Your machine doesn't have AMT (just vPro has)...
                                    that was the original problem source, you can configure something you don't have.
                                    • leone8238
                                      • 9
                                      • Slovenija
                                      Should i just ignore the error or can i do something about it?
                                      • studdy05
                                        Bricked HP Probook 450 G7 Bios questions
                                        by studdy05
                                        Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                        Ive got...
                                        07-08-2025, 09:24 PM
                                      • Vesko356
                                        by Vesko356
                                        08-11-2023, 03:27 AM
                                      • jbonavita
                                        by jbonavita
                                        Some issues
                                        Things I tried
                                        04-29-2025, 09:38 PM
                                      • Wahaz
                                        by Wahaz
                                        10-30-2023, 08:42 PM
                                      • Bloodhoundje
                                        HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                                        by Bloodhoundje
                                        I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                                        I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                                        After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                                        I have desoldered the bios chip (GigaDevice...
                                        03-16-2024, 03:12 PM
