need bios for gateway GWTN156-3BK
  • stas-karabas
    Big Member
    • Dec 2023
    • 5
    • Russia
    There is a laptop Gateway GWTN156-3BK that does not show a picture when turned on, the fans are spinning. Suspicion of a faulty BIOS. Can anyone share the BIOS dump?
    The dump was taken from the laptop using a clothespin and CH341 programmer using NeoProgrammer 2.2.0.10
    BIOS backup attached
    S\N: GWTN156-3BK20H03505
  • qayyum786
    • Aug 2018
    • 1933
    • INDIA
    YOU MUST
    POST OLD BIOS BACKUP
    POST SERIAL NUMBER/SERVICE TAG:-
    • stas-karabas
      stas-karabas commented
      Editing a comment
      Thanx. Already posted
  • qayyum786
    • Aug 2018
    • 1933
    • INDIA
    try
    • stas-karabas
      Big Member
      • Dec 2023
      • 5
      • Russia
      Originally posted by qayyum786
      try
      unfortunately there is no image output, and no via hdmi either.
      • qayyum786
        • Aug 2018
        • 1933
        • INDIA
        same status ?
        possible bios is cropped or posibale other hardwear issue
        since getaway donst provide any bios file on its support we can find another working bios
        post your mother board part number we will try to get a third party working bios for you
        • stas-karabas
          Big Member
          • Dec 2023
          • 5
          • Russia
          same status ?
          same situation.
          mb: GK7MROR_v1.1 10L (GK7MROR11T04203411497)
          • qayyum786
            • Aug 2018
            • 1933
            • INDIA
            Try this
              • 20304
              Try this one. Built with GKxMP60xN102.ROM from winraid -> https://winraid.level1techs.com/t/ne...recovery/93122
              DMI
              420000 - 42003F
              97F000 - 97FFFF​
              • stas-karabas
                Big Member
                • Dec 2023
                • 5
                • Russia
                DMI
                420000 - 42003F
                97F000 - 97FFFF​
                I checked your and the previous BIOS dump, unfortunately there is no result. Can you explain what kind of DMI data this is and what should I do with it?
                • qayyum786
                  • Aug 2018
                  • 1933
                  • INDIA
                  possible you dont have an bios issue in your board it could be a hardware issue
                  DMI means information of your laptop like your serial number your windows license key etc etc .
                  • stas-karabas
                    Big Member
                    • Dec 2023
                    • 5
                    • Russia
                    Thanks anyway for wanting to help with my problem. I will continue to look for what the problem is. All the best to you.
                    • hotcrossedbuns999
                      • Jan 2024
                      • 16
                      When plugged in the laptop battery charging light flashes, and that's the only sign of life. No screen backlight and no fans.
                      I flashed all of the fix attempts on this site (post 1 and post 2) with no improvement, except the one from this post (by volinakis). Now if I hold the power button down for a few seconds, both fans spin for a split second and turn off. No other signs of life.
                      I cant find any official bios on Gateway website.
                      I found a post on reddit where someone found that the bios for the same hardware, but with XMG Core 15 branding, worked. I don't know if that would help any.
                      MODEL: Gateway GWTN156-3BK (I think the "BK" just denotes the color as black.)
                      S/N: GWTN156-3BK20H03410
                      MOBO: MB PCB GK7MR0R_V1.10L
                      MOBO S/N: GK7MR0R11T04203411454
                      BIOS CHIP: AH1946 25B1270SIG UA7938 (I think. It's really tiny.)
                        SMDFlea commented
                        Editing a comment
                        Thread merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread.
                    • hotcrossedbuns999
                      • Jan 2024
                      • 16
                      I misunderstood the rules and thought it meant DON'T ADD YOUR ISSUES TO SOMEONE ELSE'S ISSUES, especially a two year old thread. Also, this thread didn't fix their problem.
                      Thank you for any help though.
                        • 20304
                        have you tried the bios at posts 7 & 8
                        • hotcrossedbuns999
                          • Jan 2024
                          • 16
                          Yes, I have. Same result: Battery charge flashes and that's it.
                          I saw ON REDDIT that you could use the bios from a XMG Core 15 (TongFang GK5MR0O), but it is only 13,312kb and the Bios file from my laptop and posted on BadCaps is 16,384kb. Maybe that can help you?
                          I cannot find the stock bios anywhere. Gateway doesn't even have the file on their site.
                          • hotcrossedbuns999
                            • Jan 2024
                            • 16
                            Bump.
                            Also, I'm having trouble opening this page. 9 times out of 10, this page won't open and says to contact system admins... 🤷‍♂️
                            • Habble7
                              by Habble7
                              Suspected Cause:
                              Troubleshooting Attempts:
                              05-22-2025, 07:28 AM
                            • DynaxSC
                              by DynaxSC
                              11-17-2023, 10:56 AM
                            • grimacelord
                              Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                              by grimacelord
                              This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                              Motherboard model number: DA0PAMB46A1 REV: A
                              Secondary motherboard model number: 0PAB
                              SKU: 685K4UA
                              Serial number is: 5CD3223BJP
                              Recently reflashed this laptop with latest BIOS and once...
                              05-07-2024, 08:06 AM
                            • DynaxSC
                              Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                              by DynaxSC
                              I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                              It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                              I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                              11-06-2022, 05:22 PM
                            • vinaypundith
                              Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                              by vinaypundith
                              I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                              So, I'm looking for a BIOS dump for this machine - a 16MB one....
                              08-03-2024, 12:32 PM
