need bios for gateway GWTN156-3BK
  • stas-karabas
    Big Member
    • Dec 2023
    • 5
    • Russia
    There is a laptop Gateway GWTN156-3BK that does not show a picture when turned on, the fans are spinning. Suspicion of a faulty BIOS. Can anyone share the BIOS dump?
    The dump was taken from the laptop using a clothespin and CH341 programmer using NeoProgrammer 2.2.0.10
    BIOS backup attached
    S\N: GWTN156-3BK20H03505
  • qayyum786
    • Aug 2018
    • 1933
    • INDIA
    YOU MUST
    POST OLD BIOS BACKUP
    POST SERIAL NUMBER/SERVICE TAG:-
    • stas-karabas
      stas-karabas commented
      Editing a comment
      Thanx. Already posted
  • qayyum786
    • Aug 2018
    • 1933
    • INDIA
    try
    • stas-karabas
      Big Member
      • Dec 2023
      • 5
      • Russia
      Originally posted by qayyum786
      try
      unfortunately there is no image output, and no via hdmi either.
      • qayyum786
        • Aug 2018
        • 1933
        • INDIA
        same status ?
        possible bios is cropped or posibale other hardwear issue
        since getaway donst provide any bios file on its support we can find another working bios
        post your mother board part number we will try to get a third party working bios for you
        • stas-karabas
          Big Member
          • Dec 2023
          • 5
          • Russia
          same status ?
          same situation.
          mb: GK7MROR_v1.1 10L (GK7MROR11T04203411497)
          • qayyum786
            • Aug 2018
            • 1933
            • INDIA
            Try this
              • 20971
              Try this one. Built with GKxMP60xN102.ROM from winraid -> https://winraid.level1techs.com/t/ne...recovery/93122
              DMI
              420000 - 42003F
              97F000 - 97FFFF​
              • stas-karabas
                Big Member
                • Dec 2023
                • 5
                • Russia
                DMI
                420000 - 42003F
                97F000 - 97FFFF​
                I checked your and the previous BIOS dump, unfortunately there is no result. Can you explain what kind of DMI data this is and what should I do with it?
                • qayyum786
                  • Aug 2018
                  • 1933
                  • INDIA
                  possible you dont have an bios issue in your board it could be a hardware issue
                  DMI means information of your laptop like your serial number your windows license key etc etc .
                  • stas-karabas
                    Big Member
                    • Dec 2023
                    • 5
                    • Russia
                    Thanks anyway for wanting to help with my problem. I will continue to look for what the problem is. All the best to you.
                    • hotcrossedbuns999
                      • Jan 2024
                      • 17
                      When plugged in the laptop battery charging light flashes, and that's the only sign of life. No screen backlight and no fans.
                      I flashed all of the fix attempts on this site (post 1 and post 2) with no improvement, except the one from this post (by volinakis). Now if I hold the power button down for a few seconds, both fans spin for a split second and turn off. No other signs of life.
                      I cant find any official bios on Gateway website.
                      I found a post on reddit where someone found that the bios for the same hardware, but with XMG Core 15 branding, worked. I don't know if that would help any.
                      MODEL: Gateway GWTN156-3BK (I think the "BK" just denotes the color as black.)
                      S/N: GWTN156-3BK20H03410
                      MOBO: MB PCB GK7MR0R_V1.10L
                      MOBO S/N: GK7MR0R11T04203411454
                      BIOS CHIP: AH1946 25B1270SIG UA7938 (I think. It's really tiny.)
                        SMDFlea commented
                        Editing a comment
                        Thread merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread.
                    • hotcrossedbuns999
                      • Jan 2024
                      • 17
                      I misunderstood the rules and thought it meant DON'T ADD YOUR ISSUES TO SOMEONE ELSE'S ISSUES, especially a two year old thread. Also, this thread didn't fix their problem.
                      Thank you for any help though.
                        • 20971
                        have you tried the bios at posts 7 & 8
                        • hotcrossedbuns999
                          • Jan 2024
                          • 17
                          Yes, I have. Same result: Battery charge flashes and that's it.
                          I saw ON REDDIT that you could use the bios from a XMG Core 15 (TongFang GK5MR0O), but it is only 13,312kb and the Bios file from my laptop and posted on BadCaps is 16,384kb. Maybe that can help you?
                          I cannot find the stock bios anywhere. Gateway doesn't even have the file on their site.
                          • hotcrossedbuns999
                            • Jan 2024
                            • 17
                            Bump.
                            Also, I'm having trouble opening this page. 9 times out of 10, this page won't open and says to contact system admins... 🤷‍♂️
                            • gigasi
                              • Dec 2016
                              • 97
                              • Argentina
                              Hello, I need the BIOS for
                              MB:GK7MR0R_V1.1 10L
                              MODEL GWTN156-3BK
                              SN: MAIN BOARD: GK7MR0R11T0423411520
                              SN: GWTN156-3BK20H00897
                              The device turns on the LED and turns off immediately. Thank you.
                                SMDFlea commented
                                Editing a comment
                                Post merged with Gateway GWTN156-3BK topic.
                              • 20971
                              There is an XMG bios version
                              https://www.reddit.com/r/GatewayUSA/...ash_to_enable/
                              Note the warnings:
                              I wouldn’t flash the EC as it maps a different layout of Media keys and the EC remapped that on me, so FN-F11 Brightness Down now toggles airplane mode. There is not currently a known download of either the Gateway BIOS or EC so their isn’t a way yet to go back. It also remapped the ‘Profile’ button to a Fan Boost toggle which I actually prefer.
                              Also, Flashing the BIOS will change your splash screen to XMGs instead of Gateways.
                              Proceed with caution and at your own risk.
                              The N1.03 is no longer listed but there`s a newer version N.1.15 https://download.schenker-tech.de/pa...5e3e1752684628
                              Attached is the XMG bios N.1.15 with the original Gateway EC and clean ME firmware​. It does not have your DMI but you can try it.
                              MB:GK7MR0R_V1.1 10L
                              MODEL GWTN156-3BK
                              Attached is the XMG bios N.1.15 with the original Gateway EC and clean ME firmware​ + your DMI
                              • gigasi
                                • Dec 2016
                                • 97
                                • Argentina
                                Note the warnings:
                                Attached is the XMG bios N.1.15 with the original Gateway EC and clean ME firmware. It does not have your DMI but you can try it.
                                Attached is the XMG bios N.1.15 with the original Gateway EC and clean ME firmware + your DMI
                                TNX!!
                                • hotcrossedbuns999
                                  • Jan 2024
                                  • 17
                                  TNX!!
                                  Did it work? What device and program did you use?
                                  • Habble7
                                    by Habble7
                                    Suspected Cause:
                                    Troubleshooting Attempts:
                                    05-22-2025, 07:28 AM
                                  • haitham sharabati
                                    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                    by haitham sharabati
                                    Hello engineers 😀,
                                    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                    🔧 Device Info:
                                    - Model: HP 15-da2007ne
                                    - Product Number: 8XF55EA#ABV
                                    - Serial Number: CND0338P0D
                                    - CPU: Intel Celeron N4000
                                    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                    💀 Problem:😅
                                    - Device shows “Administrator Password”...
                                    08-07-2025, 04:54 AM
                                  • Citymin
                                    by Citymin
                                    S/N : 5RNK9FFT70...
                                    08-05-2025, 05:12 AM
                                  • DynaxSC
                                    by DynaxSC
                                    11-17-2023, 10:56 AM
                                  • MDSI
                                    HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                    by MDSI
                                    I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                    Details:
                                    Model : HP OMEN 17-an012nf
                                    Motherboard Part Number : DAG3BAMBAF0 REV : F
                                    Serial Number (S/N) : 5CD7280D51
                                    BIOS chip : Winbond W25Q64VSIQ
                                    Programmer : EZP2023+
                                    Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                    I already...
                                    07-28-2025, 07:11 AM
