Hello everyone, I'm writing here maybe someone will be able to help me, for two days I've been trying to repair a notebook (ASUS K53SD) without success. the PC turns on and the Asus logo appears but it doesn't go on, it doesn't enter the bios and it does nothing else. after having done numerous tests such as changing the ram hdd etc. I read somewhere that it could be the bios, I bought a programmer (ch341a with clip) but even by flashing memory I had no results, it remains on the Asus logo screen. I attached some photos. Thanks in advance
Help ! ASUS K53SD ASUS REV.5
Tags: None
laptop serial number
bios backup -
i dont have the original bios of the pc, i took dump (copy) on this forum
MODEL :X53S
MB VER:K53SD ID3D
C3N0AS60031713F
X53SD -X191V
CHECK NUMBER :6960
CHIP WINDBOND 25Q32BVSIG1150
PROGRAM NEOPROGRAMMER - CH341A V2.2.0.10
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ----------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
i don't have the original bios file of this computer, do you know where can i get it? I have the one from this forum but it doesn't work
hi like Lisa Su suggested trying F1, theremore and first of all you have to check all Bios simple settings ! i have had few asus laptops having hanging on logo because of missing setup simple steps as to start with : do you have any os like windows or any other already installed if yes the next question is : did you play with the bios settings by any coincidence? or otherwise a bios for this asus you can find on the net (not as impossible as it looks) and you try with ch341 againfirst read if can and backup before any flashing. hope this helps a bitComment
I did as Lisa suggested but it doesn't work
I can't access the Bios, therefore I can't access the settings.
Yes Windows 10, I also changed memory from HDD to SDD, it's not a system or memory problem.
A year ago I updated the bios from Windows but had no problems.
I no longer have the original backup unfortunately.
I'm starting to think that it's no longer a Bios problem, but I can't understand what it is... are we sure that that chip in the photo is the bios? or I don't know if there is a second bios chip?
Thanks for the replyComment
okay i see, but i persist trying the basics for all possible misstepsi assume you put back old hdd (if still working) to check but yet and again u need let dryout laptop for any power left (cmos reset and let it disconnect for a while) and check battery connected as well disconnected and connect again only on wall source , and some ssd can totally go dead with a powershoratge or a heavy shake(like i had once with an ssd form ebay) and also an other time it was a dead ram/ramslot preventing device from accesing any Os...
HI ,
Well my friend just do this steps
1 - remove the main battery and cmos battery if they installed
2 - carfuly unplug screen connector on the motherboard and check for any damage or dust on the connector
3 - after you check the screen connector replug the screen caple or if you have external monitor try connect it via vga or hdmi and power on the laptop
as for the heat in the marked area .. is it from the bottom side of the board maybe pch or graphic card just see what is it and replyComment
2-removed flat cable, cleaned.
3- connected VGA and HDMI
VGA without flat cable connected to the LCD result: black screen,
VGA with flat LCD cable connected Asus logo screen.
HDMI without flat cable connected monitor result: black screen.
HDMI with flat cable connected M result: Asus logo.
Thank youComment
my friend is seems like a pch or gpu proplem
on the other side of the motherboard (bottom) there are the cpu,pch and gpu chips
the nvidia card is not integrated card
if you have some expirance i sugest to isolate the nvidia gpu first or what it called (dis to uma)
search it on the internet and see the resultComment
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
Channel: BIOS Requests ONLY!
This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 02:50 AM
This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year boardview and ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-07-2024, 01:30 AM
- Loading...
