Help ! ASUS K53SD ASUS REV.5
  • CICCIVALENTI
    • Dec 2023
    • 15
    • italia
    Originally posted by ash91
    my friend is seems like a pch or gpu proplem
    on the other side of the motherboard (bottom) there are the cpu,pch and gpu chips
    the nvidia card is not integrated card
    if you have some expirance i sugest to isolate the nvidia gpu first or what it called (dis to uma)
    search it on the internet and see the result
    I think we are getting closer to the solution.
    I think I understand, the procedure you suggest would be this one from this guy on YouTube? https://youtu.be/KuUxktKC8_Q?feature=shared​
    • Ashi
      • Mar 2019
      • Holland
      so is one of the gpu becoming too hot? laptop normally would shut off..if not keep problem search , you can look find if shorted around the bios chip and gpu etcetera, also can use a donor gpu to test if you can lean one or u can get an usb laptop tester for it ..just to add some ideas
      • ash91
        • Jun 2023
        • 31
        • SAUDI
        OK you need to check what is the combonent that gettig hot is it the gpu chip with (nvidia) word on it
        or the pch that has big letter ( i ) on it
        i still sugest to try boot the lap top without hard drive because some times it is just slow hard drive that slow down the
        boot up
        • sahamipoor
          • Nov 2016
          • 37
          • india
          IT8572e is non programmable....
          • domenico.rao
            • Nov 2023
            • 9
            • italy
            Hi, I have the Asus x53sd notebook with cpu intel i7 that doesn't show anything on the video. I'm attaching the bios because it could be that. Thanks
            • peste
              peste commented
              Editing a comment
              post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
          • peste
            • 12284
            • ROMANIA
            #26
            post S/N, full name and model, motherboard model, etc.
            • domenico.rao
              • Nov 2023
              • 9
              • italy
              #27
              C2N0AS55148309H
              X53SD-SX191V
              the main is K53SD REV 5.1
              • domenico.rao
                • Nov 2023
                • 9
                • italy
                #28
                are they okay?
                • peste
                  • 12284
                  • ROMANIA
                  #29
                  are they okay?
                  try..
                  • domenico.rao
                    • Nov 2023
                    • 9
                    • italy
                    #30
                    it does not work​
