Help ! ASUS K53SD ASUS REV.5
  • CICCIVALENTI
    • Dec 2023
    • 15
    • italia
    Hello everyone, I'm writing here maybe someone will be able to help me, for two days I've been trying to repair a notebook (ASUS K53SD) without success. the PC turns on and the Asus logo appears but it doesn't go on, it doesn't enter the bios and it does nothing else. after having done numerous tests such as changing the ram hdd etc. I read somewhere that it could be the bios, I bought a programmer (ch341a with clip) but even by flashing memory I had no results, it remains on the Asus logo screen. I attached some photos. Thanks in advance
  • qayyum786
    • Aug 2018
    • 1933
    • INDIA
    you must post
    laptop serial number
    bios backup
    • CICCIVALENTI
      • Dec 2023
      • 15
      • italia
      Originally posted by qayyum786
      you must post
      bios backup
      i dont have the original bios of the pc, i took dump (copy) on this forum
      MODEL :X53S
      MB VER:K53SD ID3D
      C3N0AS60031713F
      X53SD -X191V
      CHECK NUMBER :6960
      CHIP WINDBOND 25Q32BVSIG1150
      PROGRAM NEOPROGRAMMER - CH341A V2.2.0.10
      • CICCIVALENTI
        • Dec 2023
        • 15
        • italia
        Hello? can anyone help me?
        • hoaca388
          Badcaps
          • Jan 2022
          • 11809
          Post what you have, the bios file on the asus homepage is incomplete.
          • CICCIVALENTI
            • Dec 2023
            • 15
            • italia
            i don't have the original bios file of this computer, do you know where can i get it? I have the one from this forum but it doesn't work
            • Lisa Su
              Badcaps
              • Apr 2021
              • 213
              • Taiwan
              F1 Engineering BIOS
              • CICCIVALENTI
                • Dec 2023
                • 15
                • italia
                Originally posted by Lisa Su
                F1 Engineering BIOS
                Unfortunately it doesn't work,its's stuck on Asus screen . i don't know what to do, thanks anyway for the reply
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11809
                  Try
                  • Ashi
                    • Mar 2019
                    • 3
                    • Holland
                    hi like Lisa Su suggested trying F1, theremore and first of all you have to check all Bios simple settings ! i have had few asus laptops having hanging on logo because of missing setup simple steps as to start with : do you have any os like windows or any other already installed if yes the next question is : did you play with the bios settings by any coincidence? or otherwise a bios for this asus you can find on the net (not as impossible as it looks) and you try with ch341 againfirst read if can and backup before any flashing. hope this helps a bit
                    • CICCIVALENTI
                      • Dec 2023
                      • 15
                      • italia
                      Try
                      It doesn't work, thanks for the reply anyway
                      • CICCIVALENTI
                        • Dec 2023
                        • 15
                        • italia
                        HI ,
                        I did as Lisa suggested but it doesn't work
                        I can't access the Bios, therefore I can't access the settings.
                        Yes Windows 10, I also changed memory from HDD to SDD, it's not a system or memory problem.
                        A year ago I updated the bios from Windows but had no problems.
                        I no longer have the original backup unfortunately.
                        I'm starting to think that it's no longer a Bios problem, but I can't understand what it is... are we sure that that chip in the photo is the bios? or I don't know if there is a second bios chip?
                        Thanks for the reply
                        • Ashi
                          Ashi commented
                          Editing a comment
                          okay i see, but i persist trying the basics for all possible missteps i assume you put back old hdd (if still working) to check but yet and again u need let dryout laptop for any power left (cmos reset and let it disconnect for a while) and check battery connected as well disconnected and connect again only on wall source , and some ssd can totally go dead with a powershoratge or a heavy shake(like i had once with an ssd form ebay) and also an other time it was a dead ram/ramslot preventing device from accesing any Os...
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11809
                        HI ,
                        Yep, this is a bios chip.
                      • CICCIVALENTI
                        • Dec 2023
                        • 15
                        • italia
                        noticed something, the highlighted part when touching it is very hot immediately, do you think this is normal?
                        next solution!
                        Click image for larger version  Name:	image.png Views:	4 Size:	103.0 KB ID:	3166645
                        • ash91
                          • Jun 2023
                          • 31
                          • SAUDI
                          Well my friend just do this steps
                          1 - remove the main battery and cmos battery if they installed
                          2 - carfuly unplug screen connector on the motherboard and check for any damage or dust on the connector
                          3 - after you check the screen connector replug the screen caple or if you have external monitor try connect it via vga or hdmi and power on the laptop
                          as for the heat in the marked area .. is it from the bottom side of the board maybe pch or graphic card just see what is it and reply
                          • CICCIVALENTI
                            • Dec 2023
                            • 15
                            • italia
                            1-Yes removed
                            2-removed flat cable, cleaned.
                            3- connected VGA and HDMI
                            VGA without flat cable connected to the LCD result: black screen,
                            VGA with flat LCD cable connected Asus logo screen.
                            HDMI without flat cable connected monitor result: black screen.
                            HDMI with flat cable connected M result: Asus logo.
                            Thank you​
                            • ash91
                              • Jun 2023
                              • 31
                              • SAUDI
                              What abot the hot spot on the other side of the motherboard is there any change ?
                              is your graphic card integrated or not (nvidia , amd or intel )
                              • CICCIVALENTI
                                • Dec 2023
                                • 15
                                • italia
                                on the other side of the motherboard only USB inputs.
                                NVIDIA GFORCE 610 2GB integrated video card​
                                • ash91
                                  • Jun 2023
                                  • 31
                                  • SAUDI
                                  my friend is seems like a pch or gpu proplem
                                  on the other side of the motherboard (bottom) there are the cpu,pch and gpu chips
                                  the nvidia card is not integrated card
                                  if you have some expirance i sugest to isolate the nvidia gpu first or what it called (dis to uma)
                                  search it on the internet and see the result
                                  • ash91
                                    • Jun 2023
                                    • 31
                                    • SAUDI
                                    forget to sugest removing the hard drive if it attached
                                    and the discreted of the gpu in this asus model done by removing tow coils that are next to gpu ram chips
