dell latitude 7530 BIOS unlock
  • muramed5355
    • Dec 2023
    • 4
    hello, my name is Toni, i repair cellphones since 15 years and i have all the answers for any kind of qustion in this field, i have just now started working on laptops aned i have basic Knowledge, i have a dell latitude 7530 with a locked BIOS and i want to remove the lock, after some research i bought the CH341 programmer but iu cant read the bios IC or modify it, the 7530 have to Winbond IC´s,
    25Q80DVSIG
    25R128JVSM
    both are not selectable in the app, im using the Neoprogrammer 2.2.0.10
    any advices ?
    thank you in advance
    • 21692
    Post the dell service tag and motherboard model number please.
    https://www.badcaps.net/forum/troubl...sting?t=103570
    You MUST:
    • volinakis
      • Jan 2021
      • 2873
      • N/A
      what SMDFlea said and use ASProgrammer, just read 25R128JVSM (select W25Q128JV if 25R isn't in the list) and post bios dump here. Read chipset 2-3 times and compare results, if they are the same it means you have a good dump.
      • Danielhdd
        • May 2025
        • 6
        • España
        I need help with a dell latitude 7530 bios admin password.
        ST: C3JLPN3
        Dump file, motherboard and model attached
        I would really appreciate any help.
        Many thanks.
        • Danielhdd
          • May 2025
          • 6
          • España
          I am sorry I upload wrong file, I attach the dump file here
          • anouar ouanas
            • Mar 2024
            • 10
            • Algeria
            Here is your bios unlocked , check and give me feedback
            • Danielhdd
              • May 2025
              • 6
              • España
              Wow, That was fast, I will upload it in the morning and will let you know.
              Many thanks
              • anouar ouanas
                • Mar 2024
                • 10
                • Algeria
                Many thanks
                You're welcome ☺
                • Danielhdd
                  • May 2025
                  • 6
                  • España
                  You're welcome ☺
                  bios unlocked, excellent, thank you
                  • anouar ouanas
                    • Mar 2024
                    • 10
                    • Algeria
                    That's Good , you are welcome
                    • Akhlz001
                      by Akhlz001
                      09-20-2025, 07:15 PM
                    • gizaha
                      by gizaha
                      02-13-2024, 07:18 AM
                    • Jeff'sTech
                      Dell Latitude 7420 BIOS Unlock Gone Wrong
                      by Jeff'sTech
                      Hello everyone.
                      I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make...
                      11-08-2023, 03:30 PM
                    • jhanra
                      by jhanra
                      in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                      11-02-2024, 04:19 AM
                    • YOUCEF4787
                      Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
                      by YOUCEF4787
                      I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
                      Initial Problem:
                      The laptop was completely dead, no signs of life, no power LED.
                      Action Taken:
                      I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
                      Current Situation & The Main Issue:
                      The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
                      09-21-2025, 12:19 PM
