BIOS from HP 15-eh****** dag7hamb8i0 rev i
  • janaka
    • Dec 2020
    • 36
    • sri lanka
    DAG7HAMB8I0 This board powers on and off...but when I flashed my backup BIOS, the laptop powered on after a few days, and then the BIOS would crash again. Please help me create a new BIOS.
    backup here
    SN-:5CD201JTXP
    Model 15-eh1678AU
    proID 552KPA#UUF
    • m1ch43lzm
      • Mar 2019
      • 799
      • Peru
      Try this one I made with the clean F.26 BIOS from HP
      DMI 413000-41403F
      Windows key+"MPMLock" marker 435000-436FFF
      Product ID: 552K5PA#UUF
      But if it restarts in a loop while powering on, and the backlight turns on for a split second, it's that the battery is fully discharged/bad; i own a similar laptop (15-eh1xxx) and it does this when the battery is completely empty, letting it charge for few minutes and it powers on normally
      Try without the battery installed, it should power on normally
      • janaka
        • Dec 2020
        • 36
        • sri lanka
        DMI 413000-41403F
        ok, thanks..I tried when the battery fully charged...now I will try with your bios...
        • m1ch43lzm
          • Mar 2019
          • 799
          • Peru
          TPS65987DDJ PD controller firmware dump from DAG7HAMB8F0 board; in case someone needs it, this laptop also charges from the single USB-C port, or the regular DC jack
          Laptop model: 15-eh0xxx; should work also with 15-eh1xxx
          IC: MX25L8006E, U6102
          Content matches the first 0xB0BFh with DEVFW\Current\tps65988a.bin when you create a BIOS recovery USB from BIOS ver. F.28, also present on the EFI system partition, the rest is padded with zeros to fill 1MB
          ____
          DAG7HAMB8E0, DAG7HAMB8F0 and DAG7HAMB8I0 use different main BIOS depending on CPU model, just minor parts differences between those boards
          BID: 87C5 - Ryzen 4000 series CPU (Renoir), laptop model 15-eh0xxx
          BID: 88D0 - Ryzen 5000 series CPU (Lucienne), laptop model 15-eh1xxx
          BID: 87C6 - Athlon Gold 3150 CPU, laptop model 15-eh0xxx, maybe different board number
          • Ludmilaharhordina
            • Feb 2025
            • 35
            • Украина
            My laptop won't turn on. I need a BIOS with a clean ME region. Please help. HP Pavilion 15-eh1134ua
            DAG7HAMB81I0 Rev I
            AMD Ryzen 3 5300U Processor
            Serial number 5CD3477FJ2
            I've attached my old BIOS.
              • 21679
              DAG7HAMB81I0 Rev I
              Read the post above yours. Your BID is 88D0 / 088D0 .There is a virgin bios at post # 9 https://www.badcaps.net/forum/troubl...95#post3450195
              Copy the DMI from your backup to the new bios with a hex editor. Only the first set of offsets are relevent ( DMI 413000 - 41403F ) as there is no windows key, the 15-eh1134ua shipped with FreeDOS.
              https://support.hp.com/ph-en/product...29?sku=9H8N1EA
              • Ludmilaharhordina
                • Feb 2025
                • 35
                • Украина
                #27
                thank you
                • m1ch43lzm
                  • Mar 2019
                  • 799
                  • Peru
                  #28
                  DAG7HAMB81I0 Rev I
                  HP Pavilion Laptop 15-eh1134ua (9H8N1EA)
                  BIOS ver F.27
                  BID 088D0
                  S/N 5CD3477FJ2
                  • Ludmilaharhordina
                    • Feb 2025
                    • 35
                    • Украина
                    #29
                    thank you
                    • macabook
                      by macabook
                      🧩 Initial Issue
                      07-24-2025, 02:17 PM
                    • survivalbloke
                      Unable to extract bios file from Lenovo bios exectuable
                      by survivalbloke
                      I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                      Code:
                      "innoextract 7wcn38ww.exe"
                      it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                      The trouble I'm having is that I'm not getting the newly...
                      06-12-2024, 07:55 AM
                    • zenius
                      by zenius
                      12-08-2024, 06:13 AM
                    • lucaszmn
                      by lucaszmn
                      Problem:
                      Initial Findings:
                      • I concluded that the
                      08-12-2025, 03:01 PM
                    • JoWed
                      Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                      by JoWed
                      Hello Community,
                      I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                      07-01-2025, 09:32 AM
