NEED BIOS Thinkpad P17 Gen 2
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1356
    • France
    Hello ,
    NEED BIOS Lenovo Thinkpad P17 Gen 2
    Type 20YV
    PF3Z5XZB
    just the light flashing when plugging in the charger.
    Test without cmos : no fan, no boot, nothing.
    motherboard alone.
    No results.
    charging light present
    Maybe it comes from the bios.
    Do you have any opinions to help me?
    3.18v on Power BTN, which goes to zero when pressed
    3.24v on Bios chip
  • hoaca388
    Badcaps
    • Jan 2022
    • 12403
    Originally posted by Maxpower3
    Hello ,
    Type 20YV
    motherboard alone.
    No results.
    3.18v on Power BTN, which goes to zero when pressed​
    3.24v on Bios chip
    • kalilinux25
      • Mar 2018
      • 2093
      • ZAMBOANGA SIBUGAY
      Hello ,
      Type 20YV
      motherboard alone.
      No results.
      3.24v on Bios chip
      can you please share the motherboard code or model?
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1356
        • France
        HP550 / HP750
        NM-D491 Rev: 2.0
        Click image for larger version  Name:	403634812_889091149206811_8563377082582035027_n.jpg Views:	5 Size:	1.88 MB ID:	3163268
        2 chips 25R256 and 25B256
        Ec Nuvoton NPCX997
        It is complicated to take time to repair this type of machine.
        My boss prefers to put this straight in the trash.
        I found the Fl1 and 2 files but
        I don't really know where to cut them i have to compare them when I have the reading.
        U2001 near Ec supplied
        • qayyum786
          • Aug 2018
          • 1959
          • INDIA
          HP550 / HP750
          NM-D491 Rev: 2.0
          Ec Nuvoton NPCX997
          U2001 near CE supplied
          if you are talking about BIOS REGION than delete block 0 TO 320 from top
          Click image for larger version  Name:	image.png Views:	0 Size:	211.3 KB ID:	3163395
          than select offset from 0 TO 1000000 (0 to 1000000 is your new 16mb bios region)
          Click image for larger version  Name:	image.png Views:	0 Size:	174.2 KB ID:	3163396
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1356
            • France
            Thank you so much
            I created this file with your advice but still the same only LED lights up 3 times when plugging in the charger
            orange light with no battery comsuption 0,07A
            White light with battery same 0.07A
            Battery voltage 11.93
            • qayyum786
              • Aug 2018
              • 1959
              • INDIA
              ok
              try this new one as per your Serial Number PF3Z5XZB Bios version 1.18 and Ec version 1.09 with Clean ME
              • Maxpower3
                Maxpower3 commented
                Editing a comment
                nice, but it's always same.
                nothing and consumption 0.07A.
                there must be another problem.
                no visible damage or liquid traces
            • hoaca388
              Badcaps
              • Jan 2022
              • 12403
              Thank you so much
              Try
              • Maxpower3
                Maxpower3 commented
                Editing a comment
                same but thanks
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1356
              • France
              Some news
              Solved
              1 filter burn + 1 caps dead
              • lavie
                • Aug 2015
                • 91
                • southafrica
                ThinkPad T14 gen 4
                S/N PF4QME9Z
                Please help change logo to Lenovo one
                Hve try to crate a new tread but don't how to do it
                • trunguntilyou
                  • Aug 2022
                  • 365
                  • Vietnam
                  I wonder if it's because of the bios. My computer works everything normally, but when I open a large file (for example, an excel file of about 8M), I can't open the file. The cpu temperature is ~ 100 degrees Celsius and the fan is spinning loudly. ,, just close the open file and the computer is normal again, opening small files is normal,, I replaced the hard drive, replaced the ram, installed Windows but it's still the same.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12403
                    Click image for larger version  Name:	dataurl058856.png Views:	0 Size:	359 Bytes ID:	3337373sn:PF-3BPDFZ
                    P17 Gen 2 Laptops (ThinkPad) - Type 20YU
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12403
                      Originally posted by lavie
                      ThinkPad T14 gen 4
                      S/N PF4QME9Z
                      Wrong thread.
                        • 22084
                        ThinkPad T14 gen 4
                        S/N PF4QME9Z
                        Go to the bios requests start page/index https://www.badcaps.net/forum/troubl...-requests-only , click on the blue "+ New Topic" button
                        Click image for larger version  Name:	Capture.jpg Views:	0 Size:	29.9 KB ID:	3337534
                        • Gruezny
                          • May 2025
                          • 3
                          Hi all!
                          I have a Lenovo P17 Gen2
                          Type 20YU-003HUS
                          Serial # PF3S0LF3
                          Boot / Setup password was changed and fat-fingered, so now I can't get into the machine.
                          I have an SVOD4 programmer and Software version 0.0.5.9 date 17.03.2025. I managed to read my BIOS, dump it to a file twice and verify, then edit per instructions demonstrated on YT: (https://youtu.be/pEy-XZLU5bA?si=B4sZ6d0MSqqLHNvK).
                          HOWEVER, when I write the edited file and try to boot, I get the POST errors:
                          0271: Check Date and Time settings. (Yeah, that's expected)
                          0251: System CMOS checksum bad - Default configuration used. (Roh-roh...)
                          0177: Bad SVP data. Stop POST task. (GAH!)
                          Configuration changed - Restart the system.
                          The system never restarts - it gets stopped at the Bad SVP data - stop POST message.
                          I re-wrote the original dump back to firmware, and I'm at least booting back to the BIOS/Setup Password prompt, so I know it's got to be my edits. It would help if I knew WTH I am doing, but I'm an idiot.
                          Any help with fixing this file for me would be greatly appreciated. I'm attaching my original dump file, and my edited file for reference. My edits were done in UltraEdit, if that matters.
                          Thanks for any help the Badcaps local Brain Trust can provide!
                          • peste
                            peste commented
                            Editing a comment
                            post merged...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                        • to5it0
                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                          by to5it0
                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                          I have opened the laptop and identified the main BIOS chip...
                          10-24-2025, 01:35 AM
                        • lucaszmn
                          by lucaszmn
                          Problem:
                          Initial Findings:
                          • I concluded that the
                          08-12-2025, 03:01 PM
                        • MaxonDomkrat
                          Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                          by MaxonDomkrat
                          Hi everyone.
                          I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                          07-30-2025, 01:27 PM
                        • 1g0r
                          Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                          by 1g0r
                          First, the data in brief:
                          Manufacturer: Lenovo
                          Model: ThinkPad L15 G3 21C3-0016GE
                          motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                          IC Bios 1: MX77L25650F
                          IC Bios 2​: MX25L25673G
                          EC Chip: NPCX997KAABX
                          So far I've been a silent reader, but now I need your help
                          I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                          I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                          The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                          01-18-2025, 02:39 AM
                        • macabook
                          by macabook
                          🧩 Initial Issue
                          07-24-2025, 02:17 PM
