Need Bios for Asus X512FB
  • frattainfo
    • Jun 2017
    • 15
    • Brazil
    Hello!
    I need BIOS this model:
    Model: Asus VivoBook X512FB
    Motherboard: X512FF REV 2.2
    CPU: SRFFX (Intel Core i5-8265U)
    GPU: N16V-GMR1-S-A2
    I have already tried many bios but all of then don´t initialize GPU or initializes but not recognize drivers for it. After hours reading contents I realized that the most part of this machines uses GPU: N17S-G2-A1. X512FB uses N16V-GMR1-S-A2
    Best Regards!
    • 20855
    Originally posted by frattainfo
    Hello!
    GPU: N16V-GMR1-S-A2
    Best Regards!
    Post the laptop serial number,the original bios backup and a picture of the long white barcode sticker on the motherboard
    https://www.badcaps.net/forum/troubl...sting?t=103570
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://badcaps.net/forum/showthread.php?t=88758 )
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • frattainfo
      • Jun 2017
      • 15
      • Brazil
      Thank you for your fast reply SMDFlea​.
      Unfortunatly I don´t have the original dump. I got this machine with the wrong bios programmed in another technitian.
      Serial number: L6N0B600037623G
      X512FB-BR468T
        • 20855
        X512FB-BR468T
        Try this one. Theres no DMI or key in it.
        • frattainfo
          • Jun 2017
          • 15
          • Brazil
          Great! it worked perfectly!! Now it shows X512FB in Setup and all working perfectly includind the GPU.
          Thank you so much
          • frattainfo
            • Jun 2017
            • 15
            • Brazil
            How can I do a donation to the forum?
              • 20855
              Thank you so much
              Thats good news
              The site is undergoing some changes at the moment,the donation links aren`t working.
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • grimacelord
                by grimacelord
                07-10-2025, 02:52 PM
              • throwaway327
                by throwaway327
                Model No: RC72LA
                Serial No: SBNVKD001014459
                06-18-2025, 05:52 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • lrouw84
                by lrouw84
                Hi there,
                01-28-2023, 01:31 PM
