Bios Dump G6-1d72nr core i3
    Hello i need bios dump for g6-1d72nr core i3
    Re: Bios Dump G6-1d72nr core i3
    i got one from a i5 try this maybe it works
      ok thanks i will try tomorrow and give feedback
        here
          not working, after flashing when i pressed the powerbutton it came on for about 5 seconds then it went off again since then its dead like before only white charger led is on, i need the real bios i think my version is f.45 or so
            seems the ic is damaged not possible to program again i will get another one, got the files now
              unfortunatly the fault seems to be not from the bios but from the intel chipset, it was first turning on with no display but later it was dead only charging light comes. I changed the ic i flashed 3 different roms and still no change.
              I upload the rom here if anyone needs it, its for some of the g6 model that uses BID01695.F32
                Read this
                https://www.badcaps.net/forum/showthread.php?t=33699
                  ok i will check but i have power 3.3v and 5v and battery is also charging
