Bios Dump G6-1d72nr core i3
  • robrock1
    • Jul 2013
    • 129
    • Ghana
    Hello i need bios dump for g6-1d72nr core i3
  • dj_ricoh
    • 2073
    Re: Bios Dump G6-1d72nr core i3
    i got one from a i5 try this maybe it works
    • robrock1
      • Jul 2013
      • 129
      • Ghana
      ok thanks i will try tomorrow and give feedback
      • dycc
        Vision
        • Nov 2011
        • 625
        • Côte d'Ivoire
        here
        • robrock1
          • Jul 2013
          • 129
          • Ghana
          not working, after flashing when i pressed the powerbutton it came on for about 5 seconds then it went off again since then its dead like before only white charger led is on, i need the real bios i think my version is f.45 or so
          • robrock1
            • Jul 2013
            • 129
            • Ghana
            seems the ic is damaged not possible to program again i will get another one, got the files now
            • robrock1
              • Jul 2013
              • 129
              • Ghana
              unfortunatly the fault seems to be not from the bios but from the intel chipset, it was first turning on with no display but later it was dead only charging light comes. I changed the ic i flashed 3 different roms and still no change.
              I upload the rom here if anyone needs it, its for some of the g6 model that uses BID01695.F32
              • dycc
                Vision
                • Nov 2011
                • 625
                • Côte d'Ivoire
                Read this
                https://www.badcaps.net/forum/showthread.php?t=33699
                • robrock1
                  • Jul 2013
                  • 129
                  • Ghana
                  ok i will check but i have power 3.3v and 5v and battery is also charging
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • mkdj
                    by mkdj
                    Dear all,
                    10-19-2025, 04:41 AM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • haitham sharabati
                    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                    by haitham sharabati
                    Hello engineers 😀,
                    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                    🔧 Device Info:
                    - Model: HP 15-da2007ne
                    - Product Number: 8XF55EA#ABV
                    - Serial Number: CND0338P0D
                    - CPU: Intel Celeron N4000
                    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                    💀 Problem:😅
                    - Device shows “Administrator Password”...
                    08-07-2025, 04:54 AM
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
