hp g62 bios dump
  • asliyucegsm
    • Jun 2011
    • 351
    • Turkiye
    hp g62 bios dump
    my friend
    g62-b37st
    intel processor
    no display
    bios + kbc dump
    schematic help
    mainboard.010140u00-600-g
  • robrock1
    • Jul 2013
    • 129
    • Ghana
    Re: hp g62 bios dump
    Check this files.
    • rajeshkumar
      • Oct 2014
      • 44
      • india
      need bios dump g42 da00ax2mb6f0 rev-f
      • nacer
        • Feb 2016
        • 130
        • alger
        Good gooooooooooooooooooood
        • kokok
          • Dec 2016
          • 9
          • indonesia
          need bios G42 360TX...ANYBODY HELP ME....
          • mwmakki
            • Sep 2017
            • 9
            • Aleppo
            thanks
            • toufik sat
              • Feb 2016
              • 136
              • los angles
              thanks
              • bilalahmad
                • Aug 2016
                • pakistan
                Need hp g60 bios
                • maybel
                  • Dec 2017
                  • 24
                  • philippines
                  DO YOU HAVE hp presario cq62 REV:C BIOS DUMP
                  • kaplans26
                    • Mar 2020
                    • Türkiye
                    hp g62-b16st bios help
                      • 22281
                      Post your bios backup .
                      • kaplans26
                        • Mar 2020
                        • Türkiye
                        I accidentally deleted the backup
                          • 22281
                          You want $BID01439 see post #5 https://www.badcaps.net/forum/showthread.php?t=45741 .Use the second with no DMI ,then you`ll need to use nbdmifit to enter the DMI info https://www.badcaps.net/forum/showthread.php?t=69204
                          • trtr
                            • Jan 2021
                            • Türkiye
                            Originally posted by asliyucegsm
                            my friend
                            g62-b37st
                            intel processor
                            no display
                            bios + kbc dump
                            schematic help
                            İntel uma run bios
                            • Ahari
                              by Ahari
                              I...
                              08-13-2025, 06:12 AM
                            • mkdj
                              by mkdj
                              Dear all,
                              10-19-2025, 04:41 AM
                            • Habble7
                              by Habble7
                              Suspected Cause:
                              Troubleshooting Attempts:
                              05-22-2025, 07:28 AM
                            • haitham sharabati
                              [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                              by haitham sharabati
                              Hello engineers 😀,
                              I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                              🔧 Device Info:
                              - Model: HP 15-da2007ne
                              - Product Number: 8XF55EA#ABV
                              - Serial Number: CND0338P0D
                              - CPU: Intel Celeron N4000
                              - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                              💀 Problem:😅
                              - Device shows “Administrator Password”...
                              08-07-2025, 04:54 AM
                            • Citymin
                              by Citymin
                              S/N : 5RNK9FFT70...
                              08-05-2025, 05:12 AM
