hp g62 bios dump
  • asliyucegsm
    • Jun 2011
    • 347
    • Turkiye
    hp g62 bios dump
    my friend
    g62-b37st
    intel processor
    no display
    bios + kbc dump
    schematic help
    mainboard.010140u00-600-g
  • robrock1
    • Jul 2013
    • 129
    • Ghana
    Re: hp g62 bios dump
    Check this files.
    • rajeshkumar
      • Oct 2014
      • 44
      • india
      need bios dump g42 da00ax2mb6f0 rev-f
      • nacer
        • Feb 2016
        • 130
        • alger
        Good gooooooooooooooooooood
        • kokok
          • Dec 2016
          • 9
          • indonesia
          need bios G42 360TX...ANYBODY HELP ME....
          • mwmakki
            • Sep 2017
            • 9
            • Aleppo
            thanks
            • toufik sat
              • Feb 2016
              • 134
              • los angles
              thanks
              • bilalahmad
                • Aug 2016
                • pakistan
                Need hp g60 bios
                • maybel
                  • Dec 2017
                  • 24
                  • philippines
                  DO YOU HAVE hp presario cq62 REV:C BIOS DUMP
                  • kaplans26
                    • Mar 2020
                    • Türkiye
                    hp g62-b16st bios help
                      • 20966
                      Post your bios backup .
                      • kaplans26
                        • Mar 2020
                        • Türkiye
                        I accidentally deleted the backup
                          • 20966
                          You want $BID01439 see post #5 https://www.badcaps.net/forum/showthread.php?t=45741 .Use the second with no DMI ,then you`ll need to use nbdmifit to enter the DMI info https://www.badcaps.net/forum/showthread.php?t=69204
                          • trtr
                            • Jan 2021
                            • Türkiye
                            Originally posted by asliyucegsm
                            my friend
                            g62-b37st
                            intel processor
                            no display
                            bios + kbc dump
                            schematic help
                            İntel uma run bios
                            • Habble7
                              by Habble7
                              Suspected Cause:
                              Troubleshooting Attempts:
                              05-22-2025, 07:28 AM
                            • haitham sharabati
                              [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                              by haitham sharabati
                              Hello engineers 😀,
                              I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                              🔧 Device Info:
                              - Model: HP 15-da2007ne
                              - Product Number: 8XF55EA#ABV
                              - Serial Number: CND0338P0D
                              - CPU: Intel Celeron N4000
                              - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                              💀 Problem:😅
                              - Device shows “Administrator Password”...
                              08-07-2025, 04:54 AM
                            • Citymin
                              by Citymin
                              S/N : 5RNK9FFT70...
                              08-05-2025, 05:12 AM
                            • DynaxSC
                              by DynaxSC
                              11-17-2023, 10:56 AM
                            • MDSI
                              HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                              by MDSI
                              I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                              Details:
                              Model : HP OMEN 17-an012nf
                              Motherboard Part Number : DAG3BAMBAF0 REV : F
                              Serial Number (S/N) : 5CD7280D51
                              BIOS chip : Winbond W25Q64VSIQ
                              Programmer : EZP2023+
                              Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                              I already...
                              07-28-2025, 07:11 AM
